Question about Sony Cyber-Shot DSC-T33 Digital Camera
My flash doesn't work. I took the battery out and
My flash doesn't work. I took the battery out and held the power down for 30 seconds as instructed by the tech support. That didn't work so I also used the reset button and that didn't work either. Any suggestions?
SOURCE: TV shuts down
Remove the lamp assembly, There will be a screen on the top and bottom of the assy remove all dust from these screens. also check the tube at the top of of the lamp receptical this is an air cooling pathway. reassemble and fire it up. This worked for me and saved some serious coin judging from some of the other solutions I have seen (lamp and balast) ouch!!!
Posted on Jul 06, 2007
SOURCE: Leapfrog leapster won't turn on
Call Leapster they have replaced a few for my family and have been VERY easy to deal with. NO charge or anything.
Posted on Dec 17, 2008
  • 233 Answers
SOURCE: immediate power shutdown on Vio Desktop
I would suspect a power supply failure. It is one of the first things to go bad in a computer. From what I understand if the voltage is not correct to the motherboard (power good signal), the MOBO will send a signal back and shut down the power supply. It sounds like a safety feature to keep the MOBO from getting fried. Replace with a higher wattage power supply if you can afford it. But then it could be something entirely different too.
Posted on Dec 24, 2008
kds823
  • 112 Answers
SOURCE: ps3 turns on but not picture and won't reset. I
If the red light is lit, you'll have to call PlayStation. Otherwise check your cables. Make sure everything is securely fastened. Then try replacing the cables.
Posted on Jul 07, 2009
  • 64 Answers
SOURCE: ps3 will not power up
i think you need to call sony to get this fixed. :(
Posted on Oct 01, 2009
Packard bell laptop wont power up.
You need to check your charger first. Use a voltmeter to make sure that the output matches the prescribed output.
Oct 01, 2013 | Packard Bell Computers & Internet
Ps3 afterglow bluetooth flashes red and blue and wont let me talk, what do i do?
When the afterglow headset flashes from red to blue, it is in pairing state, youve held the power too long after power-on. Shut it off again and turn it back on and dont hold the power button untill it flashes red to blue. The directions provoded with it aare quite easy to follow. Took me 30 seconds to set mine up
Apr 09, 2012 | Mad Catz Radio Communications
Have a late 2007 macbook pro and it doesn't turn on..tried the pram smc and it still doesn't turn on is there any other way to fix the problem>?
Unplug the power cable; remove the battery then hold down the power button for 30 seconds. Reinstall the battery; plug the power back in and hold down the power button for 30 to 60 seconds and see if it starts.
Aug 01, 2011 | Computers & Internet
My Gateway M-6750 laptop was working last night but today when I tried to turn it on the power button light flashes on and off and nothing else. I have unplugged it and removed the battery and held down...
Remove the main battery and the power supply charger, allow a few minutes to get rid of any residual charge. Replace the battery, press power, if there is no change, remove the battery. Now plug the power supply back into the laptop, press the power, if it starts up the battery is bad and needs to be replaced.
Jan 13, 2011 | Gateway M-6750 Notebook
My SB600 seldom firing when triggered manually on the red flash button. Only 2 or 3 times flashing after 30 attempt. Tried with new battery but same problem occured. Help.
If you are firing the flash manually it's giving full burst each time and the battery needs to pick up the charge from the bottom. So just numbers her for an example with a full set of batteries you manually flash, first burst takes 5 seconds to charge flash again it'll take 10 seconds, if you flash it again before that 10 seconds it'll now take 20 seconds and if you push that button again it might misfire because it just can't get the power up high enough to fire it. The flash isn't a studio strobe which is plugged into an outlet, you are working with battery power and each time you flash those batteries are under a huge load and each time you fire you kill them a little more I'm surprised you are getting 30 flashes from those batteries. My guess at full power you are going to start having problems after about 12 to 15 flash bursts and it's a rapid down hill drop in performance from then on. If you took those batteries out of the flash after that series of 30 flashes I'll bet they are hot. What you can do to help is set the system up with Nikon's wireless transmitter and utilize the new i-TTL system then you are taking performance.
Jan 07, 2011 | Nikon Speedlight SB-600 TTL Flash
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
Dell inspirion 1150 won't boot up
I had this exact same thing happen. I tried everything I could think of and find out to try. For me it was a motherboard failure and installing a new one worked. .
Jan 19, 2008 | Dell Inspiron 2200 Notebook
My Iphone wont turn on
listen to solution number 4..I tried it and it worked. Hold the power and home button until the apple logo pops up and your golden
Jul 20, 2007 | Apple iPhone Smartphone
Flash problem HP R707
I've just spent 30 minutes on the phone (premium rate) to HP re this problem. The solution was as follows: switch the camera off take the battery and any memory cards out press the end of a paperclip into a small hole (which you can see with the battery compartment open) remove the paperclip after 10 seconds put the battery and memory card back in and the problem should be sorted. HP also suggest upgrading the camera firmware (which you can do via their website)
Aug 10, 2006 | HP Photosmart R707 Digital Camera
Sony Cyber-Shot DSC-T33 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
