My blower fan won't shut off it runs continuously
  • 92 Answers
Your unit is in a fault mode and you need a tech to check it out.It goes into this mode because of carbon monoxide and the danger it can be if one of the components fails.
Posted on Oct 06, 2009
I have new blower motor. it dosen't stop running
Could be a bad blower motor resistor,mounted by the blower.
Sep 28, 2016 | 2002 Dodge Ram Pickup 1500
The blower fan wont shut off
The blower motor control processor ! HVAC BLO fuse #2 30 amp -location ,rear fuse box . It is under the back seat . This is s different GM vehicle ,but still the same as your's.
Chevy Trailblazer EXT Blower Motor Won Turn Off
Jan 18, 2018 | 2004 Buick LeSabre
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
My furnace blower shuts off after 20 seconds of running
Could be a defective flame sensor and/or thermostat
Feb 23, 2018 | Heating & Cooling
My 2005 yukon has no ac blower fan control
check the resister next to the blower motor they burn out
Sep 25, 2012 | 2005 GMC Yukon
Heater won't go off
If you're referring to the heater "FAN" running continuously, then its likely to be your blower motor resistor.
The heater blower motor (under the dash) has constant power supplied from the battery, but is controlled by the blower "resistor" - usually mounted on the blower motor assembly. If one or more of the blower resistor coil wires are faulty, the motor will either not work on one of the fan settings, or will constantly run by itself.
Jun 08, 2011 | 1984 Mercury Grand Marquis
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
The blower fan does not shut off when it reaches the set temperature. Compressor shuts off but fan continues to run making the air inside very humid. Temperature is getting cold.
First, forgive me, but I have to throw the obvious out there......make sure the fan switch is in AUTO and not ON.
If the blower will not stop operating unless the main supply feed is shut off, you have a stuck blower relay that will need to be replaced.
Apr 26, 2010 | Heating & Cooling
Goodman a/c blower fan will not shut off
Unhook the thermostat wires on the furnace. If the blower shuts off then your problem is either the thermostat or the thermostat wires. If it contiues to run check you high limit switches next. If all else fails you most likely have a bad blower relay. On most modern furnaces the blower relay is part of the circuit board.
Good luck
Mar 29, 2009 | Goodman CLQ36AR49 Air Conditioner
Fan continues to run after heater is shut off
sounds like a faulty blower motor resistor.
Feb 06, 2009 | 2003 Chrysler Town & Country
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
