Question about Plumbing
I am a qualified plumber and am looking to do a course in fixing grundfos shower pumps, mains water boosting pumps and central heating pumps.Do you know where i can do these in uk or ireland
  • 832 Answers
Why not try being an apprentice of Grundfos Pumps
distributor or dealer in your area. You get both the
right training and experience working with these people.
Posted on Dec 12, 2009
No water
Does the motor turn it self off after a couple of minutes of no pumping?= ran out of water. If there is water up to the pump and still no water, check filter/s ( if there is any). Undo V band and check pump internals, impeller may be broken from shaft? When putting back together tap V band with block off wood or back of screw driver evenly as you do up the clamp to stop it distorting
Apr 14, 2014 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
Central heating pump stops running
If you can not hold your hand on the motor for a count of 10 when it has cut out, the motor has overheated and needs to be replaced or find some reason for an overload.
Jun 21, 2017 | Grundfos Garden
Problem with Shower Hardware
i am not sure as to how your central heating has anything to do with your shower, is this feed from your heating system, i would find a plumber and have it looked at
Nov 22, 2013 | Home
Triton t200re shower
Paul. Is it only the shower that the pump cuts out? i dont think we have these pumps in AU. Would bet that its a flow issue. Either remove the water saving device in the shower, if there is one. Pr turn another tap on just a dribble when you start the shower?
We have these issues with "smart"? controllers that think there is a leak
May 19, 2013 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
Low pressure from grundfos pump to house
Does your system equipped with pressure tank (pneumatic tank)? If it has, maybe it's already filled with water due to some pinhole leaks. Drain the tank and see what will happen.
Oct 30, 2012 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
Hot water at showers is intermitent while shower is on
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/Crossover.html
Set timer so pump is off when shower time arrives
Check for crossover
Check if installation is correct... is the crossover valve installed correctly?
Gene
Feb 02, 2012 | Grundfos Comfort System Recirculator ...
My Grundfos central heating pump is making all sorts of noises since I drained the system to replace a radiator valve. Any suggestions how to fix?
Did you bleed all air from the heating system after replacing the valve?
Did you bleed several times?
Gary
Apr 25, 2011 | Grundfos Plumbing
Central heating pump is very hot radiators not
need to bleed radiators or pump impellers have damage
Feb 01, 2010 | Grundfos JPS4 1 HP Pressure Booster Pump
Excellent - glad it helped .. Please feel free to leave feedback
Feb 01, 2010 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Plumbing Logo
99 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
