Question about Gestetner DSc232 Copier
Dsc232 code 571 how to reset - Gestetner DSc232 Copier
  • 68 Answers
Error code 571 is for oil overflow sensor error.If you pull out fusing unit,on the left side of it there is an oil unit attached,that has oil sensor on it.Most common problem is the sensor is getting disconnected.After you checked the sensor connection,here the procedure to reset the error code:
Turn main power switch off and back on.Then press "clear modes" key, 107 and press and hold "Stop" key for until you see screen has changed. Touch "Copy SP" tab on the screen, the press 5810 and # key. Press "Execute" tab on the screen to reset fusing error code.After that turn the main power to the machine off for a few minutes.Turn the machine back on - the error code should be gone and the machine should be working now.
Posted on Oct 06, 2009
Ricoh aficio service code sc571
solution found on copytechnet.com
sc571 on this machine means fuser oil overflow.
check the oil out sensor connector.
use sp5 810 to reset this and most other codes.
Apr 02, 2011 | Office Equipment & Supplies
AFTER THE SERVICE MODE SCREEN APPEARS WHAT DO I DO?
I guess it depends on what you are trying to accomplish. What exactly are you wanting to do in the service modes? If you are resetting a service error, then you need touch the "copy SP" on the touch screen. At the the top of the screen you will see a button that say "SP direct", touch that button. With it highlighted, enter the numbers 5810 then press # key. Then the number "1" should reset the code. If it's not the number "1" then it will be an "execute" button. After that, switch the machine off then back on. The code should be reset, unless the problem is not fixed. Then it will come back.
If that is, in fact, what you are wanting to do.
Mar 11, 2011 | Gestetner DSc232 Copier
Code 571
"Fuser oil overflow" This is a color machine right? -Carl
Jul 10, 2009 | Gestetner DSc232 Copier
Error sc 571
there is too much oil in the fuser tank(there should be little oil)
SC 571
• Defective oil end sensor
• Defective oil overflow sensor
• Defective sensor cable
• Oil supply unit not installed
you need to enter the service mode to clear the error(service tech only)
Oct 28, 2008 | Office Equipment & Supplies
Aficio 1224c copier sc 571
SC 571 is a fusing error caused by not being seated properly or the oil sensor is coated with oil.
More than likely when the machine was move oil coated the senor in the fuser and it has to be taken apart to be cleaned.
Sep 22, 2008 | Office Equipment & Supplies
Problem with copier Rex Rotary DSc232
571 A Fusing oil overflow
• The oil overflow sensor detects oil.
• When the machine covers are
closed, the oil supply unit is not
detected.
closed, the fusing unit is not
detected.
Possible causes :
Jul 08, 2008 | Office Equipment & Supplies
Problem with copier "Rex rotary - DSc232"
Hello velin viv,
The copier does not see the proper operation of the transfer belt. This is a film belt that is part of the development of the image and transfer of the image to the paper. Its critical movement is monitored. SC 481 means that either the belt is not moving, or the sensor that monitors the belts movement is bad,or the belt has torn and is physically unable to be monitored, or (save the best for last) the main controller has lost its mind and does not recognize the inputs it is given. I wish I could help you further. Typically the belt is torn, from simple wear.
Jul 04, 2008 | Gestetner DSc232 Copier
297 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
