Question about Samsung LN-R460D 46 in. LCD Television
Samsung 42 lcd loses channel lists. need each time to run auto program to regain channels
    Sergeant:
    Champion:
  • 267 Answers
YOU NEED A MAIN TOTAL ASSY OR POWER SUPPLY.
Posted on Oct 05, 2009
My lg tv is on one channel and in menu settings is not optional
Sounds like you need to re-program the TV, see if there is a Tuner, or Channel options in the menu and run auto program. Also make sure the antenna is attached before trying this.
Apr 10, 2014 | LG 42LC2D 42 in. LCD HDTV
I HAVE A RCA 42" LED TV. I RECEIVE MY SIGNAL FROM AN ANTENNA. I CAN ROTATE MY ANTENNA, SCAN THE TV FOR CHANNELS, AND THIS WORKS FINE. THE PROBLEM IS IF I HAVE TO ROTATE THE ANTENNA FOR OTHER CHANNELS,...
on B:Press the MENU button on the remote.Select Setup.Select Auto Program.Choose Air or Cable.Select Auto Program to let the TV reprogram the channels.Check that the channel is programmed into memory. There are a couple of ways to do this: Use the TV menu system. Accessing this setting varies depending on the model TV that you own. Here are two options that are common on many TV's: Option A:Press the MENU button on the remote.Use the VOL and CH buttons to move through the menu and add any missing channels try this if not r
Do a full reset if this dosnt work
Dec 25, 2013 | RCA L42WD22 42 in. LCD Television
MY TV IS STUCK ON ONE CHANNEL IS LE32R74BDAR
Set will not change channels with original remote: if up down does not work try to direct enter a channel---like 03 enter to go to 3.
If that works go into menu and perform auto program to regain all missing channels.
let me know what happens.
Mar 13, 2012 | Samsung LE32R41BD 32 in. HD-Ready LCD...
AOC L26W861 LCD TV : 1. When TV is turned on using remote, it just recycles through all the pre-programmed channels 2. Unplugged the power chord several times but is still does the same 3. Power button on...
Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Nov 06, 2011 | AOC L26W861 26 in. LCD TV
LG 20" memory problem
you will need your mainboard replaced eprom has fail
Nov 30, 2009 | LG 20LS7DC 20 in. LCD TV
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Sep 01, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
My over the air channel list program times are 1 hour behind.
I've just sorted the problem on my set , Samsung UE40S6300UXXU, L.E.D.
Enter, "menu"/system//time/clock/......make sure "clock mode" is set to "Auto" and scroll down to "Time Zone" make sure time zone is set to manual, go down to "GMT" and set it to GMT+1 and the job is done. Hope this helps
Mar 14, 2009 | Samsung LN46A630 LCD TV
Programming wrking fine, however i have no channel guide/listings
Call LG. They will have you go through diagnostics over the phone and ask for diagnostic data the TV has in memory.
I have done this about 10 times and my TV usually loses all it's TV guide data after I customize my channel listings (delete all the channels I don't susbscribe to). Within a day or two of calling them, my TV Guide is back to normal.
I will never buy another LG TV. Thank God I bought the extended warranty. I've had the power supply already replaced (this is also the 2nd set..replaced 1st set due to same issue), TV turns itself on at times ( in winter - low humidity/static electricity??), and loses TV Guide listings on a frequent basis (after I change the channel map).
Nov 26, 2008 | LG 42LB1DRA 42 in. LCD Television
Channels won't move
Go into your setup menu and choose channel program or auto scan. The TV should look for and program active channels into its memory at this time. When it is finsihed you should be able to surf normally. Otherwise you should be able to access the channels directly by entering the channel number on the rmote control.
Nov 29, 2007 | Protron PLTV-4250 42 in. LCD Television
Samsung LN-R460D 46 in. LCD Television Logo
62 people viewed this question
Jerry Greenberg
Jerry Greenberg
