Question about Brother HL-2040 Laser Printer
All four lights are blinking.
Hi. My HL 2040 printed half a page and then stopped, paper sticking out with printed text, and all four lights are blinking.
I recently moved this printer into another building that is heated only some of the time. It gets as cold as 30 degrees in there sometimes. It never gave me trouble before this move. Could this lack of climate control be a problem?
  • coyote_k Dec 23, 2007
    Well, I went up to the (cold) building where it was, and brought it down into the house. I turned it on and this time only the red light was blinking so we followed the instructions to clear a paper jam.
    No big deal. Now it is working again.
    Thanks for the fast reply. GLad I don't need a service call.
    Problem Solver:
  • 5 Answers
Turn off and back on, then let it run for 10 min. When it starts acting any different, press the go button once. (it needs to warm up, you will have the same problem if you blow it out with a can of air!)
Posted on Feb 14, 2008
  • Brother Master
  • 1,113 Answers
It depends on what error your machine has, but it has a critical error, all four lights, usally needs fuser, sometimes laser depends on what is indicated when one presses and holds the go button either way it needs to be workshoped to enable repairs to be performed.. link to lights explain on the 2040/2070
Table below is only service errors like coyote_k has. ie all four lights then press go to identify fault.
Posted on Dec 23, 2007
How to stop red blinking "paper"? couldn't stop
There is probably a paper jam since you shut it off as it was printing. Turn off the printer. Remove the tray and look inside. Remove any sheets of paper you see. Open the back of the printer (the pass-thru door) and remove any paper you see. Turn on the printer. If that fails, check the blink status against the manual's troubleshooting guide to locate a different solution.
Aug 27, 2010 | Brother HL-2040 Laser Printer
Drum light on - printer won't print
you have ran out of toner, replace it you're good to go.
Jun 03, 2010 | Brother HL-2040 Laser Printer
I have a Brother HL-2040. The "paper light is on & won't print.
Sounds like a paper jam. There's a flap at the back of the printer-once open you should be able to see if the paper is stuck there. (Exactly the problem I had yesterday-I didn't spot it at first and it nearly drove me mad! :)
Good luck,
Nov 13, 2009 | Brother HL-2040 Laser Printer
This is a paper jamb problem. There is a piece of torn paper stuck in the paper path that is stopping the printed page from exiting properly.
Sep 30, 2009 | Brother HL-2040 Laser Printer
Part printing, not the whole page
thanks for the offer, but its sorted
I have another printer, HL 2030, and I copied the driver to the HL 2040 properties, problem solved!
take care!
Jun 04, 2009 | Brother HL-2040 Laser Printer
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Mar 25, 2009 | Brother HL-2040 Laser Printer
Brother 2040 all lights keep blinking
Just got the following solution that worked for me:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Got it from here:
May 05, 2008 | Brother HL-2040 Laser Printer
Brother HL 2040
Make sure the paper aligning slides are tight to the sides of the paper. In the case that they are spring loaded make sure there is not something preventing them from holding the paper properly aligned.
The print head could be 'off-track'...
If the text is properly aligned on the edge of the page, but appears crooked it is related to the print head assembly. If the text is not aligning to the edge of the page then the paper is not feeding straight and the paper aligning slides are at fault.
It is also possible that one of the paper feed rollers are not grasping the paper and it is forcing it to one side as it pulls it in.
Mar 10, 2008 | Brother HL-2040 Laser Printer
Printer won't print full job
I think their is leser is not taking fully of the document some problem in hardware.
Sep 12, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
316 people viewed this question
James Cagle
James Cagle
Jim Keysor
