The easiest fix is to hit Ctrl-Alt-Delete, enter the Task Manager, and
then select New Task > Run. Type "Explorer" and voila, your taskbar
is back!
While spyware is not the only thing that causes this problem, (Network delays, timeouts, drive failures, and other system problems can also cause this to happen) pretty much anything that crashes explorer will also kill your task bar. I also agree with jamilahsan that it may be spy-ware and would definitely scan your machine.
I will recommend to use this TOOL. By the way, are you sure your PC is not infected with spyware? Missing a tool bar is kina an indication of worm infection.
Regards,
Jamil
do you mean taskbar?
