Question about RCA Audio Players & Recorders
Rca RS2650 5-cd shelf system works, freezes up after 1 hour or so
Here's the deal - there is a clock on the front that shows the time (of course), well the problem is when you notice the time on the clock has stop, although it is still lit, that means the whole system is locked up. The stereo will not respond to the remote, nor will ANY of the buttons on the stereo work. It just dies, except for the clock staying lit. The only way to make the system work again is to unplug it and plug it back in. This scenario can happen within a few days from first plugging it in or it may take a week or so and after it happens it WILL continue to happen.
The unit works fine except for this issue.
Please help. Thank you.
techman
  • 3130 Answers
SOURCE: CD Player Tray Spins Continuously With or Without Disk
Yuo didnt mention if it was used or new,. If it was new I wouldnt mess with the unit and take it in under warranty, as there is no quicky fix for this one. Its going to turn out to be a problem with the disc motor servo circuit or the microprocessor. Good Luck
Posted on Aug 06, 2006
MrLard
  • 94 Answers
SOURCE: Faceplate not responding / acting very weirdly
Sounds like a bad connection with the faceplate and the multi connector that the faceplate mates with when closed. check for dirt and bent pins on both connectors. Luck
Posted on May 04, 2007
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
SOURCE: projection display
To fix the projection display that is stuck with four 8's, hold down the hour and miute button at the same time. Keep the buttons pressed down while unplugging the power source then pluging it back it. I did this and the screen works like it did when I first got it.
Ken
Posted on Jan 25, 2008
  • 6 Answers
SOURCE: setting time after power been uplugged for 1 hr
I had the same problem with my Sony Dream machine of not being able to set the time after a power outage and finally figured out the sequence. Unplug power chord, plug in, then press the set time button holding until the 12 flashed, then up and down to the hour is set, then press the set time once, then the minutes flash , then set minutes, then press set time once. You seem to only get one chance for this, then if you make a mistake , you must unplug the chord and repeat the sequence. Why you cannot reset the time after setting it once, I have no idea. But I finally found at least a solution for my problem.
Posted on Jul 23, 2008
How do I set the clock?
Hello
To set clock do the folloing:
[1] Press and hold 'clock' until the hour flashes on the display.
[2] Press 'digital tuning' << or >> to set the hour and then press 'clock' to shift to minute digits.
[3] Press 'digital tuning' << or >> to set the minute.
[4] Press "PROG.SET" to save the setting and "STOP" to quit setting.
Note: When ths system is ON you can press clock to display the current time for about 2 seconds.. OK
Wish You A Happy and Prosperous 201.
Gopakumar G, Trivandrum City, Kerala State, South India.
Dec 29, 2011 | RCA RS2640 CD Shelf System
Ido not know how to set the clock on this system.
The remote control is needed to set the time.
1) Press and hold CLOCK until the hour flashes on the display.
2) Press PRESET UP or DOWN to set the hour and then press CLOCK to shift to minute digits.
3) Press PRESET UP or DOWN to set the minute.
4) Press SET to save settings.
May 16, 2011 | RCA RS1286 CD Shelf System
How do i set the clock on my rs 2635 stereo
Hello
1 Press and HOLD clock button Until the hour flashes on the display.
2 Press 'digital tuning' ' >' or '<' to set the hour and press 'Clock' to shift to minute digits.
3 Press digital tuning '>' or '<' to set the minute.
4. Press 'Prog.Set' to save setting and then 'stop' to quit setting.
When the system is 'ON' you can press 'Clock' to display the furrent time to upt 2 seconds. OK.
Jan 14, 2011 | RCA RS2635 CD Shelf System
How to set the time on my RCA RS2625
Press the clock button once. Hour number flashes. Use the tuning button to adjust the hour. Press clock button again and use tuning button again to set the minutes. There is a program /preset button below the tuning button, use that button to set, make time stay.
Sep 09, 2010 | RCA RS2652 Shelf System
How to set clock
Follow below procedures to set the clock..
1. Press CLOCK until the time flashes on the display (12-hour clock for RCA, 24-hour clock for Thomson).
2. Press TUNING UP or DOWN to set the hour and then press PRESET UP/ DOWN to shift to minute digits.
3. Press TUNING UP or DOWN to set the minute.
4. Press SET to save settings and STOP to quit setting.
Note: When system is ON, you can press CLOCK to
Regards,
Jeep Brainy
Sep 19, 2009 | RCA RS1285 CD Shelf System
Cannot set the time, need manual for our RCA RS2620 system
hold in the "clock" button until the hour flashes
use the forward & back buttons for the cd player to set the hour. (located just to the right of the equalizer" button)
once the hour is set, press the "clock" button until minutes are flashing.
use the forward & back buttons for the cd player to set the minute.
once done, press the "prog.set" button below the forward & back buttons
Dec 31, 2008 | RCA RS2620 CD Shelf System
No manual
Follow the procedure to set time/ clock.
Setting the clock
1. Press and hold CLOCK until
2. Press << / >> to set the hour
to minute digits.
3. Press << / >> to set the minute.
4. Press PROG•SET to save
settings or STOP to quit setting.
You can download user manual at RCA Support.
Regards,
Sep 07, 2008 | RCA RS2663 Shelf System
I need help
On the front of the system, press and hold Clock button until the hour flashes. Then press the Digital tuning arrows for up or down. Watch the display for AM or PM. Stop on your hour. Press and hold the Clock button again til the minutes flash. Press the Digital Tuning arrows again for up or down. Immediately press Program Set button under the Digital Tuning arrows to set the program in. If you do not press Prog Set soon enough, you will have to do the whole thing all over.
Apr 22, 2008 | RCA 100-Watt Stereo System With 5-CD...
Clock
Turn the system on and press the "Clock/Timer" button (located above the eject button for Deck 1). The clock will appear. To change the time, simply hold down either the < or > buttons (the ones you use to change radio stations and begin CD/tape playback). Press "Clock/Timer" again to lock in the time.
Dec 28, 2007 | RCA RS2622 CD Shelf System
Can you tell me how to change the clock on my RS2652?
press and hold the "CLOCK" button until the time flashes, the using the << & >> buttons, adjust the hour, press "CLOCK" once more to select minutes. again, using << & >> to select time. press "PROG. SET" once. good luck
Nov 20, 2007 | RCA RS2652 5-CD BOOKSHELF SYSTEM Shelf...
52 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
