Question about Acer Aspire 5610-4648 Notebook
Acer 5610 DC jack problem - need to dismantle laptop
My Acer 5610 power supply is working (checked) but the jack seems disconnected from the mother board.
I'm trying to dismantle the laptop but can't find a way of releasing the top cover near the screen. HELP!
  • Acer Master
  • 1,165 Answers
The solider tends to loseen up on the power connection.Make sure all screws are removed some are under the covers on bottom of laptop slightly pry the top up where ever it seems to be holding look for a screw underneath where its holding.if all screws are out it should come off fairly easy.
Posted on Oct 05, 2009
How do i power up my acer ferrari 4000
Remove main battery and try again, if nothing! check power adapter for correct voltage, If okay! sub out the ram memory one at a time and test, still no change! the DC jack is often the source of trouble and the laptop will need to be dismantled down to the motherboard level, the DC jack will probably need resoldering.
Apr 14, 2012 | Acer Ferrari 4000 Laptop Notebook
Change dc jack / no power indicator
It does sound like the DC jack, you will need to dismantle down to the motherboard, chances are the jack pin is not making proper contact with the main board, "the board is double foiled" when board has been completely removed you need to resolder the points where the DC jack sits. This is a very tricky repair and to involved to give step by step instructions, I recommend a professional.
Apr 02, 2012 | Acer Computers>Laptops Aspire 5610-2328 PC...
Acer 5610 charging difficulty
Yes! the DC jack will probably need to be resolded, and I would recommend replacing the power adapter because it may fix your problem, I find the universal supplies don't fit as tight as the original ones. www.ebay.com is a good place to start for power supply replacement.
Mar 30, 2012 | Acer Aspire 5600 Series 5610-2013 Notebook
No power at all, tried a new charger still no power and replaced the battery.
Hi
After the battery and AC cord replacement and still not getting power there's only once culprit there and that is the motherboard of the laptop. I recommend you call Acer and have them replace it for you. Thanks
Feb 21, 2011 | Acer Laptop DC Power Jack for Acer Aspire...
Power cord attachment into the back of computer seems worn, it wants to run off battery instead of recharging through power supply
Either Have A Failing AC Adapter, Or A Failing DC Jack
you can test the AC Adapter using a multimeter (available at any home improvement center for $6)..
The DC Jack Would Need To Physically Be Checked To See If It's Faulty... which would intail removal of all parts down to the motherboard and visually inspect the DC Jack (the port where the Charger Cord Plugs into)
Remove The Battery... Plug AC Adapter Into Laptop.. Attempt To Power On....
Nov 15, 2009 | Acer Aspire 5100 Notebook
My travelmate3260 DC POWER JAck pin is pulled from
The power socket needs to be replaced, but it requires the laptop to be completely dismantled to get access to the power socket on the motherboard. I suggest you get a quote for this repair.
Sep 29, 2009 | Acer TravelMate 3260-4853 Notebook
No ac power but plugged in
If you plugged in the ac adapter, and you still get no power and cannot turn it on, the first thing to check is the AC adapter. Get a voltage meter, set it to 200 DC, put the positive on the inside and the ground on the outside. Unless you have a highpower alienware laptop, it should read +/- 20 V, most likely 19.xx. If your AC adapter is good, then the DC jack, what the adapter plugs into, is bad. In this case, the laptop will have to be disassembled, the mother boared removed, the old DC jack de-soldered and taken off, and a new DC jack soldered on. You would really need to take it to a qualified techninician at a shop to di it.
Mar 21, 2009 | Acer Aspire 5100-5022 Notebook
DC input jack broken
Yes it's not usually something that can be repaired at home. Your chances are better if the jack just seems loose and not actually broken, however replacing it is better. I work for a Laptop Repair Shop in NYC and we deal with this issue frequently.
Dec 25, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer 2300 travelmate
you can get seperate dc jacks from here http://www.creativeit.tv/acer-laptop-dc-power-jack-repair.htm Try not to disconnect the screen as it may never come on again, i would take to a qualified repairer.
Aug 30, 2007 | Computers & Internet
Acer Aspire 5610-4648 Notebook Logo
264 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
