Pinkish Red color in center of the screen
Should I repair it or trash it? It's 4 years old.
    Problem Solver:
  • 10 Answers
You should actually repair it then sell it then save up for a new one because when you first take something out of the case. Right at that very sec its out dated already... Hope this worked=P
Posted on Oct 05, 2009
What causes a black screen to have a pinkish tinge with visible lines on a cathode ray sony kd34xbr960n? And what might it cost to repair?
The video output section circuits has the fault. Might be a a video output transistor short. Type {Electro-help} in your search box and enter this site. It has all details.
Jun 08, 2012 | Sony FD Trinitron KD-34XBR960 34" TV
Hi, My monitor will once in awhile go from the warm white color to a slightly red or pinkish color. The monitor is about 5 years old and the model # is AL1913. Any thoughts? Thanks. Don
Red or pinkish cast on the whole screen? You may want to check the VGA connectors and pins at both ends. Also try it with anothe PC to make sure it is not video problem in the PC.
Basic LCD monitor and LCD TV troubleshooting guides:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed LCD monitors, LCD TV's pictures: http://s807.photobucket.com/albums/yy352/budm/
Dec 15, 2010 | Acer AL1913 19" LCD Monitor
Screen Problem
In most cases where you start getting a pinkish tone or red tones....the screen is close to failing. It is not the backlight....this is the actual screen itself that is failing. There is no repairing it, it must be replaced.
Feb 20, 2010 | Acer Aspire 5100 Notebook
Pink Monitor
Are the monitor and computer both new or are they used? If the monitor is used then I would bet the problem is the backlight tubes. The backlights in LCD monitors are fluorescent lamps just like in your house or office. When the bulbs get old and about to burn out the output light changes from white to a pinkish color. At this point if your monitor is several years old and you have a pinkish display you need to start looking for a deal on a new unit. It is possible to replace the tubes but it is very hard to do because they are so small and fragile.
I hope this helps.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jul 10, 2009 | HP Computers & Internet
Pink bar across top of tv screen
This could be from 2 things. 1 is the optical block is going bad or 2 you got a peice of dust blown in from the cooling fan and its blocking the color filter internally. If you are capable you can take the tv apart and blow compressed air into the color block and remove the dust. Hope this helps
May 25, 2009 | Sony KDF46E2000 46" Projection HDTV
All color guns out of alignment
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
Nov 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Pinkish monitor
the monitor is on its way out ,
time for a new one
Terry
Mar 29, 2008 | Computers & Internet
Pinkish red screen
Your set doesnt have a color wheel you have 3 CRTs instead. Try turning down the red drive on the red crt circuit board that should help if not check the resistor that is connected to the red drive switch Vasriable resistor(switch) that is probably open if not the crt is probably at fault. If you need more info let me know.
Mar 24, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Yellow Haze Center Screen
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Mar 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
