Question about Nokia N73 Cellular Phone
Update my nokia N 73 via pc - Nokia N73 Cellular Phone
    Sniper:
  • 53 Answers
Software out of date
update your software via high speed internet.
1.Make sure you have a high speed internet connection with your PC.
2.connect your phone to PC using data cable via pc suite.
3.Download Nokia software updater from nokia.com
4.open nokia software updater and follow the instructions.
5.finish it !
Note:1. phone will restart itself several times while updating .
2.Dont disconnect phone in the middle of the update process.
3.take a backup of the data stored in phone memory because all will be erased.
4.remove sim and memory card while updating !
thanks !
vote me if satisfied with my solution.
Jan 16, 2012 | Nokia 5130 Cellular Phone
Tip
Nokia N900 Firmware Update
Nokia N900 Smartphone Firmware Update v3.2010.02-8 (PR 1.1.1)
If your Nokia N900 smartphone is freezing, hanging or acting up I recommend you update the system software / firmware of your device. Erratic behavior can often be corrected by a firmware upgrade.
Here are the instructions for updating your N900 smartphone:
Over the Air (OTA) Update
  1. From the phone's home screen key in *#0000# or go to Device manager
  2. Select Options then Check for updates
  3. Follow the prompts on the screen to complete the update
Update via a Windows PC
  1. Download and install the Nokia Software Updater
  2. Connect your N900 to your PC with the supplied USB Cable
  3. Open the Nokia Software Updater application
  4. Follow the on-screen prompts to update your device
Update via a Mac
  1. Download the 770Flasher tool
  2. Download the latest available N900 firmware image
  3. Turn the N900 off
  4. Connect the N900 to your computer via USB cable (with the device turned off)
  5. Run the 770Flasher application
  6. Drag the firmware you downloaded in step 2 to the 770Flasher application (you will get an error regarding a USB device not being found, ignore it)
  7. Turn the phone on
  8. The update process will now begin automatically once the N900 boots
  9. You are safe to disconnect your phone from the computer when you see the normal desktop reappear on the N900 display
Update via a Linux PC
  1. Download and extract the Linux Flasher tool
  4. Connect the phone to your computer via USB cable (with the device turned off)
  5. Open a Terminal window and run 'sudo ./flasher-3.5 -F -f -R' (you will get an error regarding a USB device not being found, ignore it)
  6. Turn the phone on
  7. The update process will now begin automatically once the N900 boots
  8. You are safe to disconnect your phone from the computer when you see the normal desktop reappear on the N900 display
I hope that helps.
on Apr 02, 2010 | Nokia N900 Smartphone
Hwo iam update my nokia n73 phone.
You can update your phone by Nokia pc suite and nokia updater. Firstly connect your phone with your pc via multimedia cable. Then start nokia updater. You need internet connection to your pc to update your phone.
Apr 20, 2011 | Nokia N73 Cellular Phone
How to format my nokia 6060
To get it formatted take it to your nearest nokia care. Also you can do it youself if you have broadband , pc , and a data cable for your phone. To do it yourself first download nokia software updater from www.nokia.com . install it. now connect your phone to pc by using data cable via pc suite now run nokia software updater on your pc and follow the instructions as told to. wait for 1 hour maximum(depends on internet speed).
Note:1. PC should be connected to high speed internet.
2.phone should be connected to pc via data cable only and no bluetooth or wireless.
3.phone will restart itself sveral times during update process. do not panic for it.
4. You are requested to go for it only at your own risk . take backup of every datas in your phone before the update process.
5. do not disconnect your phone while update process in progress.
Mar 24, 2011 | Nokia 6060 Cellular Phone
Software update -N73's firmware
There in nokia software updater they strictily warned for Do not disconnect mobile device from pc while update in progress it will be reposible for damage to phone.
Now you must have to contact nokia care & re-Install phone software.
Thanks.
Oct 14, 2009 | Nokia Cell Phones
Nokia n73 after disconnecting from software updater is not workin
so u have messed with ur software update dnt wrry go in a nokia care nd tell them to update ur software version of phone ur owrk is done.....
Aug 30, 2009 | Nokia N73 Cellular Phone
My phone is nokia 6500c,now when i make a call i can't be heard
could be mic has become displaced? or damaged (like by moisture etc) or could be software problem... backup your data via nokia pc suite - & update the firmware via nokia website with the usb cable supplied (instructions to update via software updater are on nokia site)
Jul 23, 2009 | Nokia 6500 Classic Cellular Phone
N73 hangs/works too slow
My N73 M phone hangs, sometimes doesn't ring and takes 15-20 secs to navigate between functions. Pls help with a solution.
i have already reset the phone by using the *#7370# code, but it still remains the same....
Help me with a solution.....
Mar 30, 2009 | Nokia N73 Cellular Phone
Nokia pc siut softwear dont able to install my phone : nokia n 73
Please find the updated nokia pc suite from the nokia website. version of the pc suite has to be more than 6.81 it would be compatibile.
Mar 27, 2009 | Nokia (nif4100fru) Modem
Nokia N73 Cellular Phone Logo
63 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
