Question about Canon ImageCLASS MF4350d Laser All-in-One Printer
Can not print pdf double-sided on Kyocera FS C5020N
I can print a word document double-sided on my kyocera fs c5020n.
But it does not work with pdf-files. With a pdf I only get the first page (onde-side) and than th eprinting stops.
Who knows what the problem is?
And the solution?
Wim
  • 622 Answers
Surprised you actually got doublesided... ok... in a situation like yours... I would update to the latest adobe reader... that has been known to give you issues with printing.... and if it continues call kyocera support... this sounds like an issue they would want to work on...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 24, 2009
How do I print double sided with this copier
pick print on both sides (flip long edge or flip short edge) in the print driver. go to kyocera support to download latest kx driver if the options are not found in your current driver
Apr 04, 2013 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
Black streaks on my output on printer fs-c5020n
chec below things
1. clean the drum unit
2. check the charge unit also
3. clean inside of the printer ...
4. check fuser unit heat roller any black streak is there...........
Nov 07, 2009 | Laser FS-C5020N Led Printer
Duplex mode.
please select print in both side options when u giving any print then only it will print both side...
Jul 02, 2009 | Kyocera Mita FS-1030D Laser Printer
FS-C5020N just put new toner in, color not print
your best bet with this one.. is to call kyocera support... they might give you a simple answer.. where as a tech will charge you an arm and a leg...
Apr 23, 2009 | Kyocera Mita FS-C5020N Led Printer
Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
Nov 26, 2008 | Kyocera FS-C5030N Led Printer
KYOCERA FS C5020N PRINTER QUEUE
remove from driver from control pannal>add remove program>
uninstall your printer driver & reinstall it i m shore its help u
Feb 21, 2008 | HP PSC 1410v All-in-One Printer
Canon ImageCLASS MF4350d Laser All-in-One  Printer Logo
311 people viewed this question
old marine
old marine
