Question about Brother MFC-5440CN All-In-One InkJet Printer
Mfc-5440cn brother said NG poor line condion/outof memory print/f
Mfc-5440cn brother said NG poor line condion/out of memory
  • 286 Answers
SOURCE: Brother MFC-5440CN Printer Problem
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the flatbed. Look on the left side. You should see a strip of glass, with the scanner sitting under it. This strip is used when the document feed is being used. Make sure it is clean. Most common problem is getting a little whiteout or the sticky residue from scotch tape on this glass, which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
Posted on Dec 30, 2007
SOURCE: Brother mfc MFC-5440CN magenta issues
You cant print in ANY color when it says NO CARTRIDGE for any one color. Sucks.
Posted on Jun 25, 2008
nonontech
  • 4737 Answers
SOURCE: My Brothers MFC 5460CN won't
This problem could be Phone line problem, or hardware failure or receiver's (the machine of the person whom you are sending the fax) machine problem and so on. First, let's check the line, if you have another Phone line, please dial from the number to your number, also, connect the currently connected line to a receiver and call a Land-line number, if the outgoing or incoming is ok, the proceed forward, otherwise, you telephone operator should check the line.
Sometimes, sending fax to a particular number doesn't work, to make sure, try sending a fax to another number.
If the line which is connected to the machine is extended from another machine such as Receiver, Switch, etc... unplug them and connect the fax machine directly to the Line.
It's also important to adjust the compatibility mode, to do this, follow the steps below:
Press Menu. Press the up or down arrow key to select Fax. Press OK. Press the up or down arrow key to select Miscellaneous. Press OK. Press the up or down arrow key to select Compatibility. Press the left or right arrow key to select Basic (for VoIP). Press OK. Press Stop/Exit.
If you place the scanning document/file on the auto-sheet feeder, you can help it pulling inside the passage or you can use the glass (flatbed) instead. Sometimes, this small mistakes with the sheet-feeder creates this problem. You can also clean the rollers inside the ADF (auto document feeder) passage.
(this problem is not related to Memory)
If all of the above measure don't help, I would suggest you to call brother and seek their help. The rest is with mechanical or we can say hardware or firmware related issue. (use this form to contact Brother)
I wish you good luck.
Thanks for using FixYa.
Posted on Aug 25, 2010
dj_relly999
  • 4070 Answers
SOURCE: My Brother MFC 887 ODW
Hi! Please try this... Unplug the unit from power source, Press the power button for 10 secs. while unplugged. This should reset the system and may resolve the problem. Hope this helps and thank you for using FixYa!
Posted on Aug 26, 2010
  • 123 Answers
SOURCE: I have a Brother MFC-790CW
Here are some solutions: http://www.fixya.com/support/t413839-ng_poor_line_condition_out_memory
Posted on May 05, 2011
My Brother mfc-665cw will not fax. It keep saying NG: POOR LINE CONDITION/OUT OF MEMORY
Check to see if you can make a call using the fax machine. This error can occur if you have no connection. It can also occur if your line is occupied or busy.
Oct 14, 2010 | Brother IntelliFAX 5750e Laser Fax
Brother MFC 5440CN The black line of the ink is "clogged"
Hello sir; If you use auto feeder and print out with black line then you have go to clean the glass (small portion one ), if you make copy with black line then you have go to clean up print head( if your machine is inkjet) or you have to replace toner cartridge ) if your machine is laser jet).
Nov 21, 2009 | Brother MFC-5440CN All-In-One InkJet...
cuando este error se produce es causado por tu linea telefonica con algun tipo de Ruido por esta razon la memoria de tu maquina se llena y te india out of memory.
Oct 05, 2009 | Office Equipment & Supplies
MFC-440CN PRINTER fax error
Plug a phone into the line and listen for static. Too many phones on the line, bad lines,etc, can cause a poor line condition. Try the unit directly into the phone line, no answer machine or anything else on the line. Maybe the memory thing is it has a lot of faxes that it hasn't been able to send.
Apr 29, 2009 | Brother MultiFunction Center MFC-440CN...
OUT OF MEMORY
Hello laray7813,
Please visit this link to know exactky what NG means and how to solve it.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000009/faq000209_000.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=12
If this dosent work, let us know and we will find other solutions,
Dahaka
Jul 22, 2008 | Brother MultiFunction Center MFC-440CN...
If you have used generic ink the head is clogged and cant be cleaned anymore.
Last chance is to use original brother ink which has cleaning fluids within the ink. Run the cleaning procedure twice and simply print 10 PAGES afterwards. Wait A DAY AND TRY TO PRINT IN MAG AGAIN:
If there will be no mag. the ph is definitley clogged and needs replacement.
Apr 16, 2008 | Brother MFC-5440CN All-In-One InkJet...
I cant fax HELP!!!!
plz see www.brother.com choose your country and your mfc.
You will find an answer to this issue within the faq. In case there are questions left, plz contact brother hotline of your country.
Apr 15, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
35 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
