Question about Sony FD Trinitron WEGA KV-27FS320 27" TV
No turn on
I haven't been able to turn it on from the remote or the manual controls. i just can't turn on the tv.
  • 647 Answers
Check that you have power to the set and does the set click?
Common fault for this model include - blown power supply transistors due to bad solder contact at horizontal drive transformer.
Read below and decide if you want to tackle the problem yourself if so I’ll help along the way with what info I have. If not contact the nearest repair shop armed with the info below.
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection).
The only way to determine the real cause is :
By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour. Be sure to vote/rate me if this helped Thanks!
Posted on Oct 05, 2009
Remote wont control tv
Long duration of storage might have damaged its inside rubber contacts at key pad. Try if after cleaning. If you wish to know how to clean a remote control, check this link.
Feb 05, 2013 | Coby TFDVD3295 32 in LCD TVDVD Combo
Emerson TV don't know size or model #
you need to use original remote to reset parental control
Apr 23, 2008 | Emerson EWC1304 13 in. TV/VCR Combo
My remote CT-90325 is saying not available when I use it to turn on tv
The remote control do hot recoganize the set. You have to setup it with your TV by using setup codes. You haven't given any details about your tV here. Then, how can one post a solution to your problem?
Jun 13, 2012 | Toshiba CT-847 Remote Control
Can I pull menu up on Trutech T2000FT without the remote?
Hello
If there isn't a button marked 'Menu' at the front panel of your TV, you can;t pull out Menu option without its remote control. No TV, which haven't Menu Button on its front panel, can't be controlled for all of its functions without its remote control OK.
Feb 13, 2012 | TruTech T2000FT TV
How do I get a manual for Toshiba remote controller model CT 90302
Hello
This remote control is for use with Toshiba 22AV500U TV. It is originally coded to use with this TV, yet other TVs also can be programmed with this remote contorl. There si no specific user manual for this remote control itself. All codes and proceedings are with the user manual for the above mentioned model Toshiba Tv. If you haven't that manual, send your email address to me by Fixya. I'll send a copy of that manual to you by return mail. Or go tho this link from where you can download the above said TVs manual for as PDF format. OK
a248.e.akamai.net/pix.crutchfield.com/Manuals/052/05222AV500.PDF
Sep 01, 2011 | Toshiba Ct-90302 Remote Control
No encuentro la clave de mi control para tv philips
Hello
Your RCA remote control should be programmed first to synchronise with Philips TV. You haven,t given any description or model number of both your TV and RCA remote. I want the model number of both the devices to help you. Send these details to me by Fixya. OK.
May 17, 2011 | RCA Universal Remote Control
I haven a RCA RCU704MSPZ universal remote control. Can you please help me get the code to use with my panasonic vcr? Thank you Peter G.
The Panasonic VCR remote codes are 008,053 for that remote. You may also try using code search. I have outlined the procedure below.
Programming a Device using Code Search:
Manually turn ON your device (TV, VCR, Cable Box)
  1. Press and "HOLD" CODE SEARCH
  2. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  3. Release CODE SEARCH.
  4. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  5. Once the device turns off, press and release ENTER.
  6. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Dec 22, 2010 | Televison & Video
RC codes for ge-24914-d to control sony Trinitron TV KV-27S42.
the codes for sony are 0128, 0013, 0002, 0071, 0380, or 0152
1) Make sure the tv is on.
2) Press and hold the set up button till the red light on the left hand corner stays on.
3) Then press tv then release quickly so that the red light flashes once. (its pretty quick so pay attention).
4) Then enter one of the four digit codes and the red light will turn off.
5) Then press channel up.
If it goes up u have the right code. If not start from the begining (holding the setup button down) and do the same steps for each of the codes, one of them should work if not u have to do a code search. Follow steps #1, 2, 3, and 5 but on step 5 press it repeatedly (for up to 300 times and it says that on the instruction manual) until the device can be controled. The red light blinks then stays lit
6) press and release mute to install the code. The light will go off.
Jun 27, 2009 | GE JASRM24912 Remote Control
I NEED TO FIND THE CHANGING BUTTONS FOR MY HITACHI TV 46EX1B
sorry but your tv moust haven the promted comand manualy olsou you need the remontcontroler Pilot4218 posibel ineed the moor detaill
May 04, 2007 | Hitachi SSF420TR 20 in. TV/VCR/DVD Combo
Sony FD Trinitron WEGA KV-27FS320 27" TV Logo
137 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
