Can't Boot PC
Bios boots fine but restarts over and over when the HDD tries to boot...???it is a VIA KM400A/KM400/KM266 PRO+8237 CHIPSET amd based mother-board?
  • 433 Answers
Sounds like the hard drive is failing. When you start the computer your operating system searches for the boot sector on the hard drive. If the boot sector is damaged the OS can't find it so it keeps rebooting to find it.
First step should be checking the hard drive.
Hank
Posted on Oct 05, 2009
    Problem Solver:
  • 10 Answers
Clean the ram and insert again....
ACER ax3470 boot
restart computer and push F12 then select DVD/CD bootable device then you can use it DVD
Jan 17, 2013 | Acer Aspire Ax3470 Desktop Pc Amd A6 3420...
I'm upgardeing my ms-7061's cpu from a 1.5 to 2.2
http://www.msi.com/product/mb/KM4M-V.html#/?div=Detail
Download > Manual >
CPU
Supports AMD Athlon / Athlon XP / Duran (Socket 462) processor.
(Socket 462 = Socket A)
Supports from 1100MHz to 3000+ model.
VIA KM266 Pro motherboard chipset - Front Side Bus support of 266MegaHertz.
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
(Same specs as a VIA KT266A but with Integrated Graphics.
The 133MHz FSB support shown is doubled. AMD processors are 'Double-pumped')
VIA KM400 motherboard chipset -
FSB support of 266MHz to 333MHz.
(Same as KT400 but with Integrated Graphics)
VIA KM400A motherboard chipset -
FSB support of either 266MHz, 333MHz, or 400MHz
(Same as KT400A but with Integrated Graphics)
Looking at the Bottom/Right corner at the CMOS battery;
There are THREE sets of jumper pins to the bottom right edge of the CMOS battery.
6 pins towards the outside edge of the motherboard, 3 pins to the inside of the motherboard. (Left side of the 6 pins)
On the 6 pins in a row configuration, the top 3 pins is SW1.
The bottom 3 pins is SW2.
The 3 pins to the inside of them is JBAT 1
In the 3 pins for SW1 the bottom pin, or pin closest to the bottom edge of the motherboard, is Pin 1.
Same for SW2. The bottom pin, or pin closest to the bottom edge of the motherboard, is Pin 1.
Jumper on pins;
SW1 pins 2 and 3, SW2 pins 1 and 2 = 266MHz FSB support
SW1 pins 1 and 2, SW2 pins 1 and 2 = 333MHz FSB support
For the KM400A (KT400A) motherboard chipset;
SW1 pins 1 and 2, SW2 pins 2 and 3 = 200MHz FSB support
1) What is the model name, and model number of the AMD processor you are going to use?
2) What kind of Thermal Paste are you using?
3) What are you using to clean the bottom of the Heatsink with, and is the top of the Processor clean?
4) Are you following Anti-Static Precautions?
Post back in a Comment.
Regards,
joecoolvette
Oct 13, 2012 | Computers & Internet
I want vga ,lan,audio driver for ms7061v1.
The MSI KM4M-V, KM4AM-V, KM3M-V Series (MS-7061 ver1.X) are all
based on VIA KM400/KM400A/KM266 Pro and VT8237 chipset.
Click on the MSI link provided to download your drivers;
http://www.msi.com/index.php?func=searchresult&keywords=MS-7061&table=download
KM3M-V driver site; http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=590
KM4AM-V driver site; http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=594
KM4M-V driver site; http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=589
Hope you find this helpful.
Cheers!
Mike
Nov 03, 2009 | MSI : MS-7061-010 Km266Prosavage/FSB333/4x...
AMD Puma-based Asus M51Ta stalls at power up, screen is blank.
Have you tried booting and pressing F2 to get in the bios?
If that works you can check the boot devices and order of usage. Make sure the HDD is first.
Apart from that you can reboot and press F8 to get in the Windows boot menu, where you can try the Safe Mode.
If all this fails, the Windows configuration is somehow corrupt. You can try booting from a Windows CD and run the Repair option in the setup.
Oct 20, 2009 | ASUS M51Ta-X1 NoteBook
Switching from 40GB IDE HDD to 500GB SATA HDD. SATA won't boot.
Hi there
No there is no need to change any jumpers on a sata drive, go into the bios settings and tell the bios to boot from the western digital drive only.
Good luck and thanks for using Fixya!!!!
Feb 09, 2009 | VIA MSI: MSI PT8 NEO-LSR P4 PT800 DDR400...
PC won't boot if SATA drive connected, drive works fine if plugged afterward
Try Hirens Boot CD. It has a lot of programs on it to detect format etc.
I think your hard drive has a missing or corrupt MBR and it needs to be replaced.
When I have had a hard dive not recognized I hve used Super Fdisk to format and reset hard drive.
On the boot disk
Nov 03, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
Sleep mode PC continued...
VIA KM400A is the name of the motherboard chipset inside your computer.
I'm fully familure with that board.
1. on boot up hit delete or F2 key to enter the bios setup screen
2. once inside the bios setup screen , look for power management settings.
you'll know what to do at that point
You'll want to
1. turn power nanagement totaly off , which is not a good idea because windows considers
it a device in the system and loads a driver for it , so turning it totaly off MIGHT give windows
a heart attack.
2. set
Display Power Management Controled by Power Management = NA or NO
Turn off display after suspend or hybernate = NO
3. save and reboot
Thank you for choosing FixYa!
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Cmos checksum error after flashing the bios
I had a similar experience after upgrading my RAM. When you reset your CMOS and have default settings maybe you should check if your RAM timings are correct. I could not get mine to load with both sticks in until I fixed the timings from the default settings.
Jan 20, 2008 | MSI K9VGM-V Motherboard
Sound
there is a problem of virus install anti virus.
manually, go to the device manager select the sound option and scan it, if the question mark in yellow appear mean not install, select it and right click it and select update driver go through it step by step select recommended process insert motherboard cd and define the path and click ok restart the system.
if u don't have the driver program then mail me u computer configuration.
Nov 21, 2007 | MSI KM3M-V Motherboard
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
