Question about Skil 2895-01 Factory-Reconditioned 18V Cordless Xdrive II Drill/Driver
Dropped unit. Cracked left side housing. Trigger will not release on own. Suggestions?
  • 24 Answers
I would suggest taking the cover off. Then get some fiberglass mat and resin/hardener and shape it back to normal. If there is no room for the extra thickness on the inside of the cover do it to the outside. You can sand it smooth once fully cured, roughly 6 hours, depending on how thick you lay it on. This will cost you less then $20.00 and you will have some left over. Sticks to almost anything and can form it however u want. Use a C clamp to hold the cover in place while resin cures. Use wax paper to keep resin from sticking to unwated whatnot.
Posted on Oct 05, 2009
How to repair cracked housing on a Philips sonicare airfloss
superglue comes to mind. Sadly, I don't know how to take it apart.
May 11, 2014 | Televison & Video
I have a turbosteamer 220 hand steamer. It heats up but won't spray steam
It's most likely the trigger not engaging the piston that releases the steam. Due to the fact that the plastic inside the 220 holding the trigger in place has cracked on both sides.It will need to be taken apart.That's another issue.Be easy on the trigger press down gentle.....
Jul 27, 2011 | Vacuums
My Snap-On 2000 PSI pressure washer is leaking through the trigger handle. I have no pressure coming out of the wand but the motor runs.
The fitting for the trigger is cracked. It happened to mine because I did not make sure the wand and hose was drained before winter came. The water left in the wand expanded and cracked the trigger housing. The problem is that the trigger piece is easily replaceable, but it is not available. Alltrade makes you buy the complete wand.
May 12, 2011 | Garden
My three year old Karcher power washer has suddenly started behaving as if it has lost its power. There is also an intermittent motor noise when I release the trigger. When I press the trigger again the...
This sounds like it had water left in it and it froze over the winter. The motot turning on and off signals a water leak on the output side of the pump. You may have a cracked pump housing. Locate the pump and make sure nothing is leaking in that area when under pressure. looh for fine hairline cracks.
Apr 01, 2011 | Karcher Garden
Water is coming out everywhere
Put a small amount of water in unit then tilt back to check. I would suspect a cracked drain pump housing.the drain pump is on the right side .left side is the recirculating pump. it is actually fairly common for these to crack the drain pump housing when a coin try's to pass through the pump.
Oct 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Senco sn2 air leak around out top only when the trigger is pulled
There is a cracked seal on the firing valve. It looks like it cant be replaced but it can. Look in your parts breakdown .It seals the firing valve to the cylinder
Apr 08, 2009 | Air Tools & Compressors
Cracked keyboard housing
u no need to worry u just make clear that u always use note book with care and if it dropped then it damaged from its base side also and the upperside is infected so it is very clear that it is not ur falt as u described.....
best of luck
Mar 04, 2009 | Apple 13.3 MacBook Intel Core 2 Duo 2.2GHz...
The flash unit for my D50 doesn't pop up automatically
The flash is spring-loaded and always "trying" to spring up. It is held down by a small lever that should disengage automatically when the flash is instructed to pop up either manually or in automatic mode. It sounds like the small lever has broken on the inside and will not release. The camera must be opened in order to repair this, and this should only be done by a qualified technician.
Mar 03, 2008 | Nikon D50 Digital Camera
Razr V3m lcd will not light up.
First,is not easy to open your unit nor replace the housing,its not like into other unit that you can open even without using a special tools for it,but i can give you an idea on how to fix it,you need ti buy a housing,flex,and backlight, to open your unit please be careful............
Nov 13, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Skil 2895-01 Factory-Reconditioned 18V Cordless Xdrive II Drill/Driver Logo
Top Skil Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Skil Measuring Tool and Sensor Expert? Answer questions, earn points and help others
