Question about Garden
Trimmer does not start, cylinder is dry after priming
  • 718 Answers
Check to see that your fuel line in the gas tank did not fall off, sometimes they get soft and fall into the tank. It will have a clunk attached to it.
Posted on Oct 08, 2009
Poulan te450 xl
Probably the metering diaphragm, or the low side of the carb needs adjusted counter clockwise in 1/4 turn increments.
Jul 10, 2014 | Poulan 17" T&E Gas Trimmer
My Echo SHC-212 floods out and will not start. Even with no choke and throtle wide open it will still flood cylinder. I have good spark.
Check your choke prime bulb and carburetor lines - sounds like its clogged and gas is barely leaking into flood the cylinder
Jan 25, 2013 | Echo Garden
Craftsman tiller won't start unless I manually prime cylinder with gas. There is no primer bulb. Can I retrofit a primer bulb in the gas line?
Hi
You can insert a primer system into your fuel system
Just follow the fuel flow below
Please take time to rate me
Bud
Oct 23, 2012 | Craftsman Garden
Will not start does not sound like getting gas
Is it priming? Is fuel getting into the cylinder? Check fuel lines for air leaks.
Aug 26, 2011 | Husqvarna 28cc Gas Line Trimmer
Have zrry30550 Ryobi Hedge Trimmer (reman.) I have good spark,good prime-up, but no fuel into the cylinder. Please help.
Hello. Get a can of starter fluid and a helper. Spray some into the air cleaner and start it up. Have your helper continue to spray a little starter fluid to keep it running for a minute or so. This will clear whatever blockage you have. Once it sounds like it is running well stop adding starter fluid and see. Joe
Jun 12, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
I can not start my ryobi 775r trimmer. There is fresh gas and the fuel/oil mixture is correct. I've gone thru all the starting procedures in the owner's manual including for flooded engine. I installed a...
Remove your spark plug, take a rag and dry it up shoot a little WD-40 into it reinstall. Do not prime the unit or turn the choke on just pull it should start for you, make sure you are are not leaving the choke on, that is a common mistake.
Oct 10, 2009 | Ryobi Three Trimmer Combo
Line trimmer not starting
The primer button may have a hole in it due to drying out. The little plastic bubble may not be priming the carburator prior to start. Leave on full choke and pull several times if still no start check for fresh and correct fuel/oil mixture if required. I am assuming this trimmer is not electric. If trimmer still fails to start or starts and runs for a moment and shuts off replace the primer button, the carb. is sucking too much air.
Sep 21, 2009 | 2006 Eagle Talon
My Homelite 26 HT Hedge Trimmer is stubborn to start and then only runs on Full Choke at full throttle, but not smoothly. Whats up with this?
Jets in carb are dirty. Take carb off and clean, blow out all jets, you may have to use thin wire to get all gunk out. Also fuel line might be dry rotted. Put carb back on and adjust settings on carb.
Jun 18, 2009 | Garden
Will start with starting fluid but will not keep running.
check your prime bulb and fuel lines for leaks just a pin hole would cause it not to prime
May 31, 2009 | Garden
323L Husqvarna trimmer
This sounds like the carb needs to be adjusted like it is letting to much fuel into the cylinder. There is supposed to be fuel and air mixture in the cylinder to make it fire. If there is to much fuel what will happen is that it will just build up in there and the air wont get hot enough as it compresses to start the engine.
May 21, 2009 | Husqvarna 28cc Gas Line Trimmer
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
