Question about Oster 12-Bottle Wine Cellar - Black
Blows hot air only inside - Oster 12-Bottle Wine Cellar - Black
  • 41 Answers
The thermocouple circuit is probably reversed. Take the unit back.
Posted on Oct 06, 2009
Testimonial: "THANKS, BUT ITS ALMOST 2 YRS OLD..."
Why my central a/c unit wont blow hot air
If its and A/c unit its not supposed to blow hot air, at least not to the inside of the house, the hot air is blown to the outside, if its working properly.
Nov 05, 2014 | Heating & Cooling
My nextbook8 'shuts while i'm on it
heat problem, shuts off ??.. if its gets hot... try putting your hand by fan outlet and see if you a getting hot air blowing,, or see if bottom on pc is very hot,,if no air and below is really hot.. then its the fan, or if its very little air and very hot ,then its junk,mock stuck in the little holes inside fan outlet.. use a can or air and blow it out..
Jan 20, 2014 | Tablets & eReaders
2009 galant, added coolant.. still blowing hot air
Hi, there are several reasons your vehicle may be blowing hot air through the vents, such as a need to recharge refrigerant. There could also be a problem with the air conditioner's compressor. Vents will blow hot air if the compressor does not activate when the A/C is turned on. There may be an obstruction in the system, or the blend air door inside the HVAC unit may be stuck in the HEAT position so no air goes through the A/C evaporator.
May 25, 2011 | 2009 Mitsubishi Galant
1995 Lincoln town car A/C problem-blowing hot air
it blows out hot air and the lines is hot
Jun 01, 2010 | 1995 Lincoln Town Car
S-Type blowing hot air inside the car
take it back and have them check the valve they installed maybe its stuck / needs bleeding of air ..
Mar 25, 2010 | 2006 Jaguar S-Type
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Hot air blowing in car
sounds like your blend door motor has gone bad. this motor controls the blend door in the heater box that allows eather cold or hot air to flow or a mixture of both. replacing this motor is a big job cause the dash must be moved out to get to the motor.
Apr 05, 2009 | 1998 Lincoln Town Car
Air flow and heating problem inside dryer.
???? this doesnt make much sense, can see how you would be measuring air flow within the cabinet??? air blowing out unit strong means your gettin good air flow fom within, that is a direct relation as to the amount of (hot) air being pulled across the clothing
Jan 14, 2009 | Whirlpool LER4634J Electric Dryer
Only blows hot air inside
Set thr thermostat to AC instead of HEAT.
Dec 29, 2008 | Carrier 36KCARMS Air Conditioner
Oster 12-Bottle Wine Cellar - Black Logo
240 people viewed this question
Top Oster Furniture Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
jasbo
jasbo
james laughton
james laughton
Are you an Oster Furniture Expert? Answer questions, earn points and help others
