trying to connect Playstation3 to my insignia 37". I connected the cable to the AV2 slots and switched tv to AV2 and still it says no signal.. what am i doing wrong?
You might want to try a factory reset on your PS3 = turn it off then hold down the power button for 5 seconds it should then Beep.
There is a small memory in the PS3 that stores info about the tv that is was Initially setup on. IF you do this reset this should allow you to connect it to your Insignai tv
Another Tip i would do is connect it all up with it turned off then power up your appliances once its all connected.
I have U-Verse cable by AT&T and I purchased a new Flat screen Insignia TV 23'' but it will...
(More)
I have U-Verse cable by AT&T and I purchased a new Flat screen Insignia TV 23'' but it will not work with the AT&T remote what code can I use.
Insignia NS-LTDVD26 TV screen will cut out after several hours use - still has sound but picture...
(More)
Insignia NS-LTDVD26 TV screen will cut out after several hours use - still has sound but picture screen goes black. Picture will come back on after turn off/turn on. What can fix the problem?
i have a insigna television manufacturer june 2007 lot # 123794xht071139, i wanted it to know if the...
(More)
I HAVE A INSIGNA TELEVISION MANUFACTURER JUNE 2007 LOT # 123794XHT071139, I WANTED IT TO KNOW IF THE TELEVISION COULD BE PUT UP ON THE WALL.
