Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Chamberlain 1265 garage door opener, tried to
Chamberlain 1265 garage door opener, tried to close the door and the sensors spotted something and lights flashed, so moved the object and closed and now the door only closes to within an inch of the floor...tried opening and re-closing a few times to no avail....any ideas. Thanks. Keith
complete model no. 1265-267LMC
    President:
  • 3,197 Answers
On the side of the motor unit you will find the 'down limit control'. Using a small screwdriver turn this control in the same direction as the arrow printed on the cover. Some tweaking may be necessary to get it just right.
Posted on Oct 05, 2009
Owners Manual for Chamberlain Garage Door opener. Model 2265R
Unfortunately, the 2265R is not a Chamberlain supported model. The manuals for supported garage door openers are list here: http://www.chamberlain.com/parts-and-support/installation-manuals . The manual for the 2265 is here: http://www.chamberlain.com/CatalogResourcesV3/en-us/shared/files/tucmanuals/A2497M.PDF . There is also the 2265C: http://www.chamberlain.com/CatalogResourcesV3/en-us/shared/files/tucmanuals/A2512M.PDF .
It could be that the 2265R is a refurbished model. Then the manual for the 2265 garage door opener will give you the the correct manual.
In my experience, when the garage door goes down partway and then reverses completely, the problem is something breaking the light beam between the safety sensors. This can be a piece of grass or the shadow from the door when one or both sensors are getting full sun. If the problem is some weed getting pushed into the sensor range, simply cut the nearby grass shorter. To check if the problem is a shadow, try getting a couple of people to stand near (but outside) of the garage door. They should be positioned to cast a shadow on the sensors. If the door closes properly when the button is pressed, then the solution is to wait for a slightly different sun position to close the door or to continue to hold the button on the wall panel.
I hope this helps.
Jun 14, 2016 | Building Materials
Lift-master 1265 Garage Door opener clicks but nothing happens
CHECK ON THE OPENER FOR A RESET BUTTON, IT MAY HAVE JUST POPPED.
Apr 10, 2013 | Sears Craftsman LiftMaster Chamberlain...
I am locked out of garage. Liftmaster 1265 will not open.
Sounds like what you need acces too is inside the garage. If you don't have a pedestrian access door to your garage, or a window, or these are both locked, you are going to have to break something. Sorry to tell you that. Just pick the thing to break which is easiest to repair. Once inside, there is a mechanical release (usually a pull rope hanging from the opener main unit) that allows you to open the door manually. Then you can use the garage until you can address the problem. Good luck.
Oct 23, 2012 | liftmaster Chamberlain Garage Door Opener...
Liftmaster 1265 closes and then immediately opens garage door. Pulling chain release does not release chain. Only way to keep door closed is power shut-off; performing very rapid return when reaches...
There are two possibilities here. First is if the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Second is if the door is reversing when it hits the floor. This is a problem with the door traveling too far in the down direction. Locate the 'down limit' located on the side of the motor unit and turn it a bit in the opposite direction of the arrow printed on the cover. Some tweaking may be necessary.
To release the door with the rope - pull straight down and then pull the rope in the direction away from the door. This should lock the mechanism in the open position. To release this pull straight down and release.
Sep 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: Can I bypass the sensors on my garage door opener?...
You cannot bypass the sensors but you can try reversing their position so that the sun isn't hitting the receiving unit. You can also move them back from the door or use something like the tube inside a roll of toilet tissue to shade the lens.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener (liftmaster 1265) buzzes when attempting to open or close the door but the chain doesn't move
Remove the cover from the motor unit and check the drive gear. It is white nylon and is just in front of the motor. Most likely stripped.
Apr 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1265 won't motor more than a foot in the down
Check, The black interruptor cup. See if it has powder from gear on it , Remove particles, And run a Q-Tip between the two little towers on the RPM sensor, Which the interruptor cup rotates into to count rpm cycles.
Dec 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a Chamberlain 1265 Lift-Master Professional. Does that model still exist or if not, what has replaced it. Also who carries it
I know that that is a lift-master opener. chamberlain owns lift-master. but if its a new opener your looking for try the lift-master 3800 jack shaft opener. it features a low profile design that mounts next to the door instead of on the ceiling above the door, and also incorporates a battery backup so that you will never be locked out again.
Oct 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
643 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
