Question about Craftsman 25cc Gas Line Trimmer
We have a Toro gas-powered weed wacker and cannot figure out how to remove the top to replace the wire?
  • 420 Answers
SOURCE: I have a 32cc crasftzman weed wacker need how to
This can be a little tricky, the filter is in the tank connected to the line. The line is pulled through a hole in the tank which seals only because the line is the correct outter diameter to seal the hole and not collapse the interior. Fuel line and filters are available at most places that carry outdoor power equipment parts but you must make sure the line is the exact size inner and outter as the original.
If the trimmer has a primer bulb the line goes from the tank to the bulb and then to the carburetor, a second line goes from the carburetor back to the tank, don't get them mixed up.
Posted on May 14, 2009
ar15guy
  • 3 Answers
SOURCE: Hve a Craftsman Weed Wacker 24 cc Need to find out
http://www.craftsmanlawn.com/WeedWacker_Weed-Trimmer/358.795310/
Go to VIEW MANUAL. Then the process you seek is on PAGE 10.
Posted on Jul 26, 2009
moretons
  • 155 Answers
SOURCE: 2-cycle toro weed wacker does not start
Sounds like the flywheel has come loose and sheered off the key which locates it on the crankshaft without this the timing will be out ,
Posted on Aug 04, 2009
  • 41 Answers
SOURCE: Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
Posted on Apr 14, 2010
  • 19 Answers
SOURCE: I need a replacement head for my 25cc crafstman
You can find a complete trimmer head replacement at Hyperparts.com. Go into the Lookup By Application section and select the make and model of your trimmer to see a list of the heads they offer.
Posted on Dec 13, 2010
Replace head on toro model #51954 curved shaft trimmers
https://video.search.yahoo.com/yhs/search;_ylt=AwrTcdIyalFXg.QAUmAnnIlQ;_ylu=X3oDMTByNWU4cGh1BGNvbG8DZ3ExBHBvcwMxBHZ0aWQDBHNlYwNzYw--?p=Toro+Model+51954+Weed+Trimmer+Owner+Manual&fr=ytff1-msgr&hspart=mozilla&hsimp=yhs-006
Jun 01, 2016 | Toro Garden
17" 32cc gas weed wacker
Hi pmbaugardne...
Please take time to rate me
Sep 19, 2011 | Craftsman Garden
Need to fine gas tank replacement part for craftsman weed wacker model number 04182N501231
Hi mperez40
Go to the following webpage and you will be able to locate what you need and be able to order it also.
It is the Sears Parts webpage with will also have phone and email support in case you canhnot locate the part by yourself.
Please rate me
http://www.searspartsdirect.com/partsdirect/product-types/Grass-trimmer-weed-wacker-Parts
Jun 25, 2011 | Craftsman 25cc Gas Line Trimmer
Have a toro 51940 model gas weed wacker that just won't start. What's the most common reasons? I replaced the spark plug already!
Check and clean the air filter. That's always been my problem. Wash/dry add a drop or two of oil and work it in.
May 07, 2011 | Garden
Have a Ryobi weed wacker 725r 31cc click link Trimmer Plus. No more line-can't figure out how to remove bottom to replace the line or what kind of line to replace with. Deceased husband lost directions...
i also have a ryobi weed wacker. if it is the same. you don"t have to remove the button. line up the 2 arrows one on wheel with bumpy edges and one by the button. you should see 2 holes feed a 2-3 foot piece of line into the hole the line comes out of for cutting and it should come out of a curved holw on the bottom by the button .tuck the end into a small round hole . pull line tight (tug on the section that you cut with). wind the string by turn the ring around the button. til desired length. if this doesn't work. google you model # and look for a manual (manual for ryobi weed wacker model # ------------.)
Jun 09, 2010 | Garden
Sears Weed Wacker Line trimmer trouble starting, then stops after a few seconds.
hi
how do u remove the head assy on 13" toro rimmer?
plz help
tx
Sep 08, 2009 | Craftsman Garden
Jul 17, 2009 | Craftsman 25cc Gas Line Trimmer
Replace pull cord on ryobi model cs30 weed wacker
Good fix, mrfixit-jerr! Also, if you remove the rear cover (4 screws) you can stabilize the crankshaft by inserting a screwdriver between the lobe of the shaft and the counterweight.
Apr 03, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Istuctions for fuel line installation on weed wacker
The esiest way to figure it out is to take the line with the filter and put it on one nipple then push on the primer a few times and see if fuel comes out of the other, if no fuel then switch the line over to the other. But if im not mistaken the filter will go to the bottom.
Oct 20, 2008 | Homelite Consumer Products 4.0 Amp, 13 In....
Craftsman 25cc Gas Line Trimmer Logo
351 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
