Question about Belkin (F5D5231-4) Router
Downloading Problem When trying to down load any thing using the belkin g wireless rounter the downloads start fine but die before completion of the file.  Usually getting to or just under 1 meg in size.  Running directly from my modem I don't have this problem, as well as it seems to be effecting two of my machines (one xp, one vista) and all browsers I have tried on them (Fire Fox, IE, Netscape). Surfing from page to page dosn't show any type of problems, only the download its self seems to be effected.  It also seems to make little difference be it  connected directly to the router or going wireless.
  • Anonymous Jan 06, 2008
    I have exactly the same problem and I`ve tried everything I can think of and nothings worked so far.
  • Anonymous Jan 07, 2008
    same problem when trying to load music from limewire!!!!!!!!
    Novelist:
  • 188 Answers
See if belkin has a firmware upgrade for your router - They may have already found and fixed a bug in the router and you just need to install it.
http://www.belkin.com
Posted on Dec 25, 2007
We have a belkin wireless G router with three computers on it. All computers get the signal and signal is very strong. However, since about a month ago, downloading from the internet is quite slow and...
Perhaps one of your neighbors is leeching off or your connection. Is you router secured?
If you are serious about fixing, I will need to connect with you remotely to take a look. I have the software needed to connect.
Email: ultrasleekgeek@gmail.com
Aug 15, 2010 | Belkin (F5D6230-3) Wireless Router
The belkin rounter of my dad's laptop was installed without password setting. i tried to set it up on 192.168.2.1 configuration page. i was notified that the rounter will restart again itself...thereafter...
If you can still remember the password that you entered on the configuration page, follow the steps below:
1. In the lower right corner of your screen (near the time and date), right click on the wireless network connection icon, then select view available wireless networks. Or, if your wireless adapter has its own wireless utility, you should see that in the lower right corner of your screen.
2. You should see the router's wireless network name (SSID). By default, the SSID is "belkin54g". Select the SSID and it will prompt you for the network key.
3. The network key is the password that you entered on the router configuration page.
If you cannot remember the password that you entered, follow the steps below.
a. Connect your computer to the router using an ethernet cable.
b. Access the setup page by typing 192.168.2.1 in the address bar.
c. Go to Wireless -> Security. Copy the network key.
d. Then follow steps 1-4 above.
For the MAC computer:
1. From the Airport menu, select the SSID.
4. When asked for a password, enter the network key that you entered on the router.
I hope this helps!
Jun 13, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Change the IP address
There are a couple of things you could have done. Did you turn DHCP off? Are you just trying to use this as a WAP? The easiest thing to do is plug your computer into one of the ports on the Belkin, and nothing into the LAN port, do an IPCONFIG release and an IPCONFIG renew and let the computer get a new IP address. Then try logging into the gateway address displayed.
If you're doing a WAP, set an SSID, set the IP address to your 235 and gateway to 1, turn off DHCP, or let it pass through, because you're going to let the Linksys give out all IP's, then plug the linking cable into network, NOT USING THE WAN port. From the network, you should be able to ping 192.168.1.235 if you can, point your browser to that address and see if you can now log into the Belkin.
If you run into trouble, comment back and I might actually download the manual :-)
Carl
Nov 07, 2009 | Belkin F5D7234-4 Router
Wireless freezes
i had a similar problem with my old belkin usb adapter, i simply downloaded the new Belkin Wireless Utility and it fixed the problem. If your usb isnt belkin try downloading the drivers or latest software of whatever manages your wireless usb adapter.
Jun 03, 2009 | Computers & Internet
Lost of Internet
"Because it is a belkin!"
Basically, your wireless router is not capable of handling the load of heavy downloading, and locks up.
Mar 06, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Restored factory settings on pc & cant re -instal belkin adaptor
The Belkin site has very specific instructions for installing this adapter in a pc with Vista. These instructions are at: http://www.belkin.com/support/article/?lid=en&pid=F5D9050&aid=6112&scid=0
I would first unistall any Belkin Software that has already been installed, shut down the system completely and then restart. After you have fully restarted the system then follow the Belkin Site instructions EXACTLY. Any variation is apt to mean an unsuccessful install. Good Luck and have patience.
Nov 14, 2008 | Belkin 802.11g Wireless Desktop Network...
I have purchased a belkinf5d8233uk4 and have trouble connecting to virgin broadband as cable from virgin into modem is screw in can you help
you still have to use the modem from virgin, mine is setup the same but with a different router, you have the virgin rounter connected to the wireless router then the belkin wireless rounter connectes to you pc instead of the virgin router, your gonna have to log onto the router and setup some security to make the connection safe from others using it.
Sep 08, 2008 | Belkin Computers & Internet
Belkin wireless G
You need to run again the set up cd for it to reinstall the card back and to make it work again on your computer....
Jul 03, 2008 | Belkin Desktop Card Network Adapter
Belkin N Wireless Router Problem Downloading
Try to use different browsers to download. e.g. Opera, Firefox.
If issue persists please provide more information how lockup happens (Connection freezes or Computer itself)
Good Luck
Dec 30, 2007 | Belkin (F5D7231-4) Wireless Router
Belkin (F5D5231-4) Router Logo
54 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
