Question about Sport & Outdoor - Others
Dc side of my electrical seems to short out
I have a 1989 bayliner my dc cabin lights work when they feel like working the engine is a new 3 litre and it seems like something around the electical juction needs tightening this doesnot seem to be the problem thx if you can assist gary
    Problem Solver:
  • 20 Answers
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
aaa5
Posted on Oct 10, 2009
Bayliner boat cabin cruiser 1986 26 ft with gm motor and volvo penta carburator Need owners manual
What engine? 4cyl, 6 cyl, 8 cyl? 2.1 2.3 2.5 3.0 3.8 4.3 5.0 5.7 7.4liter?
Jul 31, 2017 | Volvo Boating
Have a 2001 bayloner throphey how much fuel it holds
Are you sure you don't have a 2001 Bayliner Trophy? ;>)
7 gallons, but they come in sizes 17 feet to 31 feet and 125HP to 225HP.
2001 Bayliner Trophy Asking Price: $13,999 OR BEST OFFER Condition: Good. Description Location: Ridgewood, New York Seller's Notes: AWESOME BOAT!! Body Style: Power Boat Length: 21 Hull: FIBERGLASS Class: FISH/SKI BOAT Engine: 2010 Hyundai 150 # Engines: one Fuel Capacity: seven gallons Horsepower: 150 VIN: Request the VIN Seller's Comments Great boat, Lots of storage, 270 hours on motor, Well maintained, Reliable, Great for the lake, Depth/Fish/GPS System, Well equipped, Live well, Pump, Anchor, Seats four, Lots of cabin room, Equipped with toilet.
Easiest way is to run it dry with a 1 gallon portable can on board. Stay close to the marina until main tank runs out, top up with the gallon can, and then go to the marina and fill it up. Whatever it takes minus 1 gallon is the capacity. Then refill that gallon can and log how many miles you do on a full tank. I carry 2 x 6 gallon tanks, I know one tank will take my 95 kilometres (I am in Canada)
Red portable fuel marine tanks hold 6 gallons. The size is marked on it. If you have a fixed tank, they are usually 20 gallons, but to be sure use my method and a fill.
Bayliner Trophy 2002
May 14, 2016 | Cars & Trucks
ATC FUSE KEEPS BLOWING OUT, 2000 SILVERADO Z71 1500, WHAT CAN I DO TO FIX IT? THE FUSE FOR ATC IS BLOWN, EACH TIME I PUT A NEW FUSE IN IT BLOWS IMMEDIATELY. I CAN'T GET MY TRUCK OUT OF 4 WHEEL DRIVE.
IF the fuse blows immediately, you've got a dead short. Trace the wiring harness backwards from the transfer case and shift motor, looking for chaffing or rub through.
Jan 28, 2018 | Cars & Trucks
Got new battery 3 months ago. new battery is dead and wont take a jump. also can not put car in nuetral to push car.
It sounds like you have an electrical short someware in the system. You can check this by first disconnecting the negitive cable from the battery. You will need a meter that will measures DC voltage a multimeter works fine. Set the meter to 20 volts DC put one lead on the positive battery terminal red to the red and the black lead to a good engine ground like a clean spot on the engine block. If you read voltage there is something shorting to ground and this will drain the battery even with the vehicle off. The shift problem is likely related to the dead battery
Dec 24, 2010 | 2005 Chevrolet Cobalt
The check engine light came on in my 2005 KIA Sportage, after driving in a lot of rain and 100 miles away from home. The car doesn't seem to be running right. It's an automatic and seems to sort of...
SOUND LIKE ELECTRICAL PROBLEMS THE ALTERNATOR ON LOWER SIDE OF THE ENGINE.IF INNER FENDER SPLASH SHIELD MISSING WHEN DRIVING ON WET ROADS WATER WILL GET THROWN THROUGH INNER FENDER WELLS FROM CAR TIRES IF SPLASH SHIELD NOT IN PLACE WATER CAN SHORT ALTERNATOR OUT AND GET THE IGNITIONS COMPONENTS WET CAUSING ENGINE PROBLEMS.IF A AUTO ZONE OR ADVANCE AUTO PARTS STORE NEAR BY GET THEM TO SCAN CAR THEY WILL DO IT FREE TO SEE WHAT CAUSING CHECK ENGINE LIGHT TO COME ON.
Jun 14, 2010 | 2005 Kia Sportage
I need wiring diagram for boat 1993 Bayliner jazz engine: mercury 90 hp 3 cylinder 2 stroke jet serial no:oeo31008
can't start my 1993 bayliner 1400 jazz. replaced key switch, kill switch today. I got the boat last week running.
Sep 24, 2009 | Boating
98 cherokee starts for 2 seconds and shuts off.
Sounds like a serious short and or blown fuse. Check battery voltage. Move on to underhood fuse block. Check all fuses. Move on to cabin fuse block. Check all fuses. Check fuel cut-off switch. Reset switch. If you still have the problem and the battery is good than you have a short in your starter, alternator , or fuel pump. I won't go into lighting cause I figure you can tell a bad bulb from a good one. If your battery voltage is 12v + with the engine off your ok. If you can start the engine, check the voltage at the battery again, it should now be around 14v. If not , go to the positive terminal on your alternator and check the voltage there. If you read 14+ at the alternator and not at the battery , then the wiring in that circuit needs to be changed. A quick alternator test is to disconnect the negative terminal of your battery while the engine is running. If the car dies then your alt is bad. If you read lower than 12v on your battery. disconnect it, add water unless its maintenance free., charge it on a charger or preferably get a new one. Go and feel your starter for excessive heat. A short will also heat up your negative battery terminal
Jun 28, 2009 | 1998 Jeep Cherokee
Electrical Probelm: 1997 3.5 Litre V6 NK Pajero (Montero) GLS
chech fuses on boos bar under steering columb and also chech for wires shorting to ground take a look at the relays also
Jun 20, 2009 | 1995 Mitsubishi Montero
Power windows, sunroof, interior lights not working. Fuse?
I just saw your posting. Yes, It could be a fuse, a 10amp interior light fuse BUT... I had to replace the Central Locking Control module which toasted first... I had the 3 open door, no working lights/windows situation too...
The problem seems to be in the main cabin light which has the 3 way rocker switch. Turn this off (depress the side on the driver side of the car (US)). Check the 10 amp fuse for the interior light. If it is burnt, you are OK if its not, you need to replace the Central Locking module. ~$200 US
I still have not replaced the cabin light module where I think a short is. If I replace the fuse in question, and turn the cabin light on, it "pulses" for a few minutes and then cooks the fuse.
May 09, 2009 | 2004 Audi A6
1989 Chev Cheyanne 4x4
if its got antilock brakes,then its trying to say "HELP"im not working correctly--probaby bad sensor at the wheel either side front,or bad electric motor that drives the antilock brake system
Dec 18, 2008 | 1989 Chevrolet C1500
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
