Question about Sport & Outdoor - Others
My printer started to print after it was turned on
I have difficulty in standing so that when I did stand I saw all the lights were on. I turned the printer off, but now the printer will keep printing until iy runs out of paper or jams.
    Scholar:
  • 110 Answers
Delete all jobs in the print queue, THEN power cycle the printer.
Posted on Oct 06, 2009
My2002 R1 won't start no green neutral light when I turn the key the yellow check engine light lights up
Hi, Kevin the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
neutral light wont come on when in neutral and wont start with kick stand.
No neutral light bike won start
Yamaha YZF R1P Service Manual
OEM parts for Yamaha
Yamaha YZF R1P Owner Manual
Sep 22, 2017 | 2002 Yamaha YZF-R1
How do I set up a scoll saw
You will need to put your saw so the the height of it puts you in a comfortable position while you saw. Some saws have their own stands and some people mount their saw on a home made stand or bolt them to their workbench. Make sure you have a really good lighting over your saw. Again some saws come with an attached light but most are not really very well designed and a better light overhead light usually works a lot better. Make sure you have a couple of feet of clearance on either side of your saw because you will be constantly turning your cutting piece and need to have the unrestricted room to do so. Before you start sawing you need to adjust your blade and table to 90 degrees use of a square is necessary and not relying on the saw's gauge. Put in your blade , making sure blades teeth are pointing down and set the tension. You should've ready to saw.
Oct 19, 2014 | Saws
HP Officejet 5610 All-In-One. cartridge error: refer to device documentation to troubleshoot ... I was in the process of of printing a series of documents. does not print prpoperly
Will it color copy- stand alone? Try making a copy on the printer by itself. If the copy is still printing in blue, then go to the service section in the menus, and clean the print head, if that does not work then try the recalibrate function. -If the copy comes out fine when you try it stand alone, try deleting the printer and reinstalling the printer.
Mar 28, 2014 | HP Officejet 5610 All-In-One InkJet...
The printer show offline
Is this network printer or stand alone printer?
For both, check the power of printer.
For network printer, check print server is working, network cable from printer to print server is fine, check your computer connect to network.
For stand alone printer, check cable connect between your computer and printer.
If they are all good, restart your computer to let windows pick up your printer when it start up.
Hope this will help. Thanks for reading
Jul 18, 2011 | Office Equipment & Supplies
My Canon iP90 has been working perfectly but now won't work at all. Nothing. Not a bleep. The green light's on and I've done all the utility checks and they're fine. I've tried turning...
Hi.
If you had done utility check and they are fine, had you try printing on a stand alone not using a computer. if you can print on a stand alone, there is no problem on the hardware side of the printer because u were able to print on a stand alone. you can focus now on the software side by uninstalling and re installing the driver of the printer and that should work.
Jun 10, 2011 | Canon PIXMA iP90 Mobile Printer
Rigid 14" Band Saw Stand Bounce
Yes, take it back to the store that sold it and get them to replace or repair the problem. Hope this helps!
May 04, 2010 | Ridgid 14" Band Saw with Stand
Cant i run a stand alone self test on my deskjet
o check printing capabilities, print a Self Test Report. In order to print such a test follow the next steps:
  1. Turn the printer on and place media in the tray.Set the width adjusters to fit tightly against the sides of the paper in the tray.
    1. Press Power button while opening and closing the printer access door four times.
    2. Release the Power button.Your printer will print a test report.
Oct 28, 2009 | HP DeskJet 3740 InkJet Printer
My Kyocera Mono Laser Printer is stopping between each page
call a service technician to clean the paper feed rollers... they aren't picking up the paper... this triggers the error so you have to stand there and manually reset the error and it prints...
Jan 21, 2009 | Kyocera FS-1030D Laser Printer
Ink absorber is full and printer won't print
Dear caucoin,
This message appears when waste ink absorber capacity rise to about more than 95 %. To fix this problem you need reset waste ink counter and it strongly recommended that you replace waste ink absorber (integrated in print base unit). Due to complicated disassembly process i suggest you to take the printer to nearest service center. For emergency reason you may perform below procedure to reset waste ink counter:
  • Plug in power cable
  • Press POWER button while holding down RESUME/CANCEL button then release RESUME/CANCEL button (do not release POWER button)
  • Press RESUME/CANCEL button two times while holding down POWER button then release all button (printer entering service mode and light stand by in green).
  • In stand by condition, press RESUME/CANCEL button 4 times (light will flash alternately in orange & green each time the button pressed).
  • Turn off printer and turn on again.
Now your printer back to normal condition. Hope this will be useful for you and don't forget to rate me.
Regards,
Source:
Canon Inkjet Forum
Dec 10, 2008 | Canon PIXMA iP90 Mobile Printer
Sport & Outdoor - Others Logo
56 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
