Question about ASUS Z71 (90-N9Q1G1000) (90N9Q1G1000) CD-RW/DVD-ROM (Combo) Burner
Serivce ligth on says,"service 4 wheel drive". The 4 wheel drive indicator light will NOT come on & $ wheel drive will not work
    President:
  • 1,564 Answers
Your vacuum actuator on the front axel is not functioning. this may be caused by several things such as a poor vacuum supply to the unit, dirt or grease build up within the unit, a broken housing due to road debris etc.etc.
Posted on Oct 05, 2009
    Sergeant:
    Novelist:
  • 191 Answers
Some vehicles have fail safe that prevents engaging 4WD while a trouble signal is active. This prevents 4WD drive from being damaged.
Most auto parts centers can plug a trouble tester in to your vehicle's computer to define more exactly what the trouble signal is indicating.
You may want to take vehicle in for a service check of the 4WD components most notable the seals.
1995 Ford Explorer 4 wheel drive trouble, front wheel drive doesn't work
Something you can do is to tap the 4/4 motor under drivers side on the back of transfer case with key on engine off. Have someone work the buttons as you gently tap the motor. Don't hit so hard as to dent it. Usually works.
Feb 22, 2013 | 1995 Ford Explorer 4.0
Won't go into 4 wheel drive. Light says service 4 wheel drive.
I had the same problem. If you have any soldering skills there are two plugs on the back of switch, there are tabs that hold the box together,carefully release them and it will come apart. One plug has 5 pins & one has 4 just heat and apply touch of solder to each one. My 4wd would work some of the time,when I went over rough roads the yellow indicator light would flicker. Haven't had a problem since. Good luck
Jan 09, 2010 | 2006 Chevrolet Silverado
03 Trailblazer service 4 wheel light activates while turning
check the lubricant in the transaxle, if it is low it will cause the light to come on.
Sep 21, 2009 | 2003 Chevrolet TrailBlazer
Service 4 wheel drive comes on at times on 2002 trailblazer
there is something wrong with you 4wd system might be electrial problem get it check be gmc service tech for diag code
Mar 08, 2009 | 1999 GMC Jimmy
2001 GMC Yukon 4 wheel drive problem
hav you changed the AWD fuse under the hood?
Jan 28, 2009 | 2001 GMC Yukon
4 wheel drive does'nt work on my 1999 jimmy
change the selector switch first it is by far the cheapest
Dec 07, 2008 | 1999 GMC Jimmy
4 wheel drive on my jimmy won't engage
try disconecting the battery to reset service light may not solve the problem but should allow u to put truck into 4 wheel
Dec 04, 2008 | 1999 GMC Jimmy
Computers & Internet Logo
306 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
