Question about Vacuums
Kirby g4 problem
Hi, i got a used kirby g-4 and the brushes dont turn and it has very weak suction,what in the world is wrong with this thing?????????????????????
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
1. Take the brush roll and belt off the vacuum. Put the head back on the vac.
2. Turn it on and see if the bag inflates with good power. Does it sound normal? This will tell you if the problem is with the motor. If you have a good inflation of the bag and a bad noise in the motor, you need to take it in for service. If the motor is fine, you need a new spinning brush assembly.
The screw heads of the brush roll face towards the floor so you can adjust them while the brush is in the vacuum. When you turn them clockwise the brush comes down and gets closer to the floor for better carpet cleaning. You should also change the belt on that vac once a year. Just because the belt isn't broken doesn't mean it's o.k. Once they stretch out the power from the motor is lost and the brush won't clean anything.
Posted on Oct 09, 2009
How do I fix suction on kirby sentria upright vaccum
  1. Put the hose and see if suction is good. If it is - you may have had nozzle installed wrong or brush roll may be worn out (bristles must be sticking out of the nozzle by about 1/8 of an inch).
  2. If there is no suction with the hose either - check if bag is not overfilled to the point where dirt is blocking the fill tube hole.
  3. If two above are fine - something must be blocking the air passage from the fan to the bag. Check for clogs in the fill tube (tube inside the cloth bag) and mini emptor (bag bottom plastic part) and also see if there is something blocking the exhaust on the vacuum. You may not even see it so use a piece of wire.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 20, 2014 | Kirby G3, G4, G5, G6, Ultimate, Diamond,...
The green light is not coming on and kirby is not sucking
HI There,
When the green lights do not come on when vacuuming with a Kirby, this indicates that your belt has either broken or fallen off. There is a magnet on the beater bar that activates the LED green light when it's spinning.
Here's a helpful video tutorial that we recorded, that will show you how to replace the belt, as well as perform basic maintenance on your roller brush to prolong the life of your belt as long as possible.
Video Repair on How To Check The Belt on a Kirby Generation G4:
I hope this was helpful! If you have any follow up questions, please feel free to use the comment field here on Fixya.
If you need to purchase a new roller brush, or belt for your Kirby G4, here are direct links to those parts on our website:
Kirby G4 Roller Brush Assembly:
http://www.govacuum.com/kir108.html
Kirby G4 Agitator Belt:
http://www.govacuum.com/kir143.html
If this repair was helpful to you, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by the Fixya community when someone answers your questions.
Thanks again,
Chris Jones
GoVacuum.com
May 14, 2010 | Kirby G4 Bagged Upright Vacuum
Kirby G4 motor is very loud. It has suction but seams to be a lot louder than when we bought it in 1996.
Hi There,
Most likely it's just the fan that is making the noise rather then the motor. The way the Kirby vacuums are designed, anything hard that's vacuumed up such a coin, or other hard things can break the fan.
In order to check and see if it's your fan, remove the front part of the vacuum that contains the roller brush and belt. If you're not sure how to do this, here's a video that shows you how to change the belt, but will also explain how to get the front bell shaped housing off:
Once you have the front cover off, look inside the vacuum directly behind the motor shaft. You will be able to inspect the fan here. Turn the motor shaft which also turns the fan, and see if there's any cracks, or if the fan blade is broken. I think most likely you'll see the fan damaged somehow.
Here's a video repair that we've put together that explains step by step on how to replace the suction fan on your Kirby:
Part 2:
Hopefully this helped you fix your Kirby. Please be so kind and rate the repair, or leave feedback if this was helpful to you. Thanks so much,
Chris Jones
GoVacuum.com
May 02, 2010 | Kirby G4 Bagged Upright Vacuum
Kirby g4 brush wont turn belt ok
your belt has probably been stretched to the point where it will not work so good.
Jul 02, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G4 without suction
change your belt, if there is suction from the hose, and you cant see any blockages in the area where the brush roll is then you need to change the belt, even if it isnt broken. putting your hand over the nozzle to feel the suction is not the way to tell if it has suction.
Oct 15, 2008 | Kirby Ultimate G Bagged Upright Vacuum
No suction on kirby g4 upright vacuum. Can't use attchments.
First remove the mini-emptor and check for a clog also check the fan for anything cloging that or the hose may be clogged
Jul 07, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Suction?
You won't feel a great deal of suction like you tried to do it. But look at the fan, if it isn't worn down, and the bag fills with air when you turn it on, then the suction should be ok. If you haven't changed your belt in awhile, I am sure that it is stretched and is having trouble turning the brush roll.
May 20, 2008 | Kirby Ultimate G Bagged Upright Vacuum
My kirby has no suction
Even if you have a new belt, do everything this guide tells you to do. The seller may have the power nozzle assembled improperly. If the brushroll is in wrong or the base plate is not on correctly, it may cause these symptoms.
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps,
Marci
Nov 10, 2007 | Kirby G6 Bagged Upright Vacuum
Roller brush doesn't move
Here is a online guide....it's for the G series Kirbys. They're similar enough that it should help. Pay special attention to the belt lifting process...it's exactly the same as for the Heritage II, and it's also where I think your problem lies. I have a Heritage II manual available too! Hope I have helped...
Marci
Oct 26, 2007 | Kirby Heritage II Vacuum
Vacuums Logo
48 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
