Question about Sport & Outdoor - Others
Power seat crown vic 89
Power seat will not move is it switch. in my 89 crown vic front seat
    Problem Solver:
  • 20 Answers
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
a7
Posted on Oct 10, 2009
Dash an tail lights not working on a 89 crown Vic it's not the fuse already checked it is good
Ck the bulbs, ck for power & ground at the sockets w/ headlights on, Poss headlight switch, relay & fuses with a test light.
Jun 10, 2017 | Cars & Trucks
Why won't 89 cRown Vic stay running unless key held forward
Usually the problem is inside the lock switch. You should have power at the EEC relay and the coil with the switch in the on position.
Jun 14, 2015 | 1989 Ford Crown Victoria
Fuel pump relay location
Yes In the trunk of some of the Crown Vics there is a switch next to the air ride control. It is called an Inertia switch and has a reset button. If you do not find this switch in the trunk, you will find it behind one of the kick panels above the front seat floorboard. It will sometimes activate by mistake with an impact.
The fuel pump relay should be in a Relay trio that is piggy-back to the Powerbox under the hood on the driver's side. There are plastic clips on one end which when pressed will allow the Relay trio to slide out of the case and towards the engine.
Oct 22, 2013 | Ford Crown Victoria Cars & Trucks
"I have a 95 ford crown vic and the key ignition is stuck in the on position and i tried a new key ignition switch but it didn't work it was still moving freely wat is the problem now"
it sounds like the ignition cylinder has dropped a tumbler not sure of replacement procedure for ur car but it needs the ignition cylinder replaced
Jan 12, 2013 | 1995 Ford Crown Victoria
1987 thunderbird computer reset
87 Thunderbird and 89 crown vic can use the same computer if they both have the 5.0, the numbers do have to match on the computer, a taurus 3.0 computer is not compatible.
Jul 05, 2012 | 1987 Ford Thunderbird
Front seat of 1993 crown vic is loose or broken
look under seat and u will ee the rails on each side of seat rock seat back and forth to locate wich bolt is loose or broken or if the rail itself is broken if rail broken remove the seat and order or go to a junkyard for the rail
Mar 02, 2012 | 1993 Ford Crown Victoria
1994 ford crown vic front pass. side power window regulator...
Yes it is. They will need to be drilled out. Thats the best way, some people try to put bolts on, but I dont advise it.
May 12, 2010 | 1994 Ford Crown Victoria
How do i remove the door pannels
remove the screws for the catch all box ot the bottom of door, remove the window switch and the two hex head screws that hold the door panel on under the switch. remove the screws under the arm rest and remove it. When that is done it just un snaps from door
Mar 12, 2010 | 1989 Ford Crown Victoria
89 Crown Vic brake lights work when park, not when moving.
Replace, or adjust your brakelight switch located on the brake pedal arm.
Sep 16, 2008 | 1989 Ford Crown Victoria
Sport & Outdoor - Others Logo
63 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
