Jenn-Air JJW8230D Electric Double Oven
Problem for Jenn-Air JJW8230D Electric Double Oven
What does error code F2 mean and how do you solve
By specialista on Oct 05, 2009
What does error code F2 mean and how do you solve the problem?
Solution #1
posted on Oct 05, 2009
Not Rated)
localwonder
Rank: Guru  Ovens & Ranges  Expert
Rating: 92%, 3014 votes
HI, this code represents an issue that concerns the controls ability to read true oven temperature correctly. This will require you to Ohm test the oven temperature sensor, if OK, replace the power relay board.
Was this helpful?
Yes
No
Popular Solutions for Jenn-Air JJW8230D Electric
Questions and Unsolved Problems for Jenn-Air JJW8230D Electric
Do you recommend Jenn-Air JJW8230D Electric Double Oven?
Answer
Answer
I have a Jenn Air double wall oven. When I press the "Cancel" button for top oven or any... (More)
Answer
Wall oven door will not release after the automatic cleaning cycle. Booklet says to push temp clean,... (More)
Answer
i have a jenn-air double oven how do u no if the key board is bad.
Answer
The beep is regularly irregular, that is, it beeps at regular intervals, and then stops for a while... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Oven Experts
Top Range & Oven Repairmen
(972) 859-0929
Honest, Dependable, Affordable, Available &...
Appliance Parts & Repair Service
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
