Question about Samsung ML-2510 Laser Printer
Changing Ink cartridges - Samsung ML-2510 Laser Printer
How do you remove ink cart.
To replace an ink cartridge on a Kodak ESP C310 follow these steps:
1) Make sure your printer is on.
2) Lift the printer access door, and wait for the carriage to move to a position where you can access it. The ink cartridges are located in the printhead.
3) Pinch the tab on the ink cartridge.
4) Lift the ink cartridge out of the printhead.
5) Remove the new ink cartridge from its bag.
IMPORTANT:To prevent the printhead from drying out, insert the ink cartridge into the printhead immediately.
6) Remove the protective cap from the cartridge.
7) Insert the ink cartridge into the printhead.
8) Press down on the ink cartridge tab until you hear a click.
9) Close the printer access door.
That completes changing the ink cartridges.
Thank
Mark
Aug 25, 2014 | Kodak EasyShare Office Equipment &...
Changing ink and had some one take it out now have new ones and not sure witch one goes were
Insert the black ink cartridge into the left slot of the ink cartridge holder and the colour ink cartridge into the right slot of the ink cartridge holder.
Dec 07, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    I have no way of changing the ink cartridge in my printer.
    Hi, the information you need is here:
    http://support.epson-europe.com/onlineguides/en/sc46/index.htm
    Just click on the replacing ink cartridges on the left hand side, follow the instructions and pictures there.
    Jan 13, 2010 | Epson Stylus C46 InkJet Printer
    I changed the black ink cartridge and the printer
    Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
    Have some test on it at Printer Maintenance.
    I'm sure 100% works on it.
    Sep 23, 2009 | Office Equipment & Supplies
    Turn on your printer and raise the lid or press the cartridge changing button. Wait for the cartridge carrier to slide out.
    Lift the cartridge holder lid, and the cartridge will pop up for removal.
    Carefully remove the tape from the ink opening on the bottom of new cartridge.
    Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
    Close the cartridge holder lid and press the cleaning button to charge the cartridge.
    Close printer cover.
    Mar 07, 2009 | Epson Stylus C86 InkJet Printer
    Here is how to get the ink cartridges to move to the changing position on the R320.
    1. Press the paper jam/ink button on the printer control panel.
    2. A menu comes up. 1st item is ink cartridge replacement. Press
    OK button.
    3. Another menu with ink cartridge replacement. Press OK button.
    4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
    Hope this helps.
    Aug 05, 2008 | Epson Stylus Photo R320 InkJet Printer
    Did you secure the latches when reinstalling the cart? You should hear a clicking sound.
    If you had used generic carts before it might be that the cart led control circuit can be stained with splashed ink. This cant be fixed anymore. you need a new cart holder!
    Jan 11, 2008 | Brother MultiFunction Center MFC-440CN...
    Samsung ML-2510 Laser Printer Logo
    37 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    Victorman
    Victorman
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
