On going problems with our model mahh5500b maytag neptune washer
We described our problem with you before of the washer not running the correct hot or cold water which was selected and also the soap dispenser was not working. We went through all the simple things of changing the hoses around in which we were told that it was probably the main control board in which we ordered and replaced. The soap dispenser works but it selector still runs the opposite water that was selected.
What next. We have had nothing but trouble with this machine and have spent $300.00 or more on it. Please help
  • 2 more comments
  • bagpiper Dec 25, 2007
    my wife won't let this machine go
    The water pressure on both the hot and cold water are good. The problem is that you set the washer to wash hot and rinse cold doesn't happen. It runs hot all the way through. I have thought about checking the screen but if they were clogged then you would have low pressure on either one of them which isn't happening
  • bagpiper Dec 29, 2007
    I spent $9.00 to get advice on our problem As of this date of Dec.29 2007 fix ya has not come up with anything useful to our problem. I have had no response in the last few days.
    I didn't spend $9.00 to have you tell me to buy a new washing machine How can you sell a washing machine that doesn't work properly to start with. I have to much invested to let his go. I need to know what other electrical component would be causing the problem
  • 259 Answers
Make sure to check the screens on the water connections located on the back of the washer. I have had problems before with screens that are blocked restricting the flow of water to the washing machine.They can be taken out and cleaned with A tooth brush. Low pressure on hot or cold water could change the temperature that you select. Another problem could be the fill valves that fill the washer going bad.(stuck or not opening.) They are not as expensive as control board or timer on some models.
Posted on Dec 25, 2007
    Master:
    Sergeant:
  • 482 Answers
Hello, I am sorry for your lost time and money. I know you would like to fix this, but at what cost and time you are willing to put in it. You can buy a new one for what you have spent in time and money. I would sale it, and get anything back out of it you can, and go get you a new one with a warrenty. Good Luck. Farren
Posted on Dec 24, 2007
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune washer model MAH5500B and the error code is "Lr"; what does this mean?
your machine has a fill problem either your screen is pluged on the water hose either hot or cold or your water is turned off.
Sep 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune key pad ocassional working
The machine control pad, with the LED lights, is going out. Replace this control pad and all lights should be working normally again.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
We just installed the MAH9700AWM Maytag Neptune and got an error code OE? We cancelled cycle, etc still getting issue.
The "OE" error code means the control detected the water level in the machine is above the overflow level. According to your description the first failure suspect is the water valve possibly stuck. Perform the troubleshooting as described in the tech sheets.
Here are the break down diagrams for the Maytag Neptune washer Model MAH8700AWW
Feb 25, 2010 | Maytag MAH9700AWM Neptune Front Load...
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune Model #: MAH5500BWW is flashing
The error code you describe is not listed in Maytag's book of codes. The link below will take you to Maytag's website error code page where you might be able to match it up.
http://maytag.custhelp.com/app/answers/detail/a_id/2885/session/L3NpZC8yY3lEMjNEag==/sno/0
Jul 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune front load washer model # mah55oobww
you've got the hot and cold hoses reversed, switch them.
Oct 21, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune Washer, model number MAH5500B
check for a kink in the drain hose. if not remove the front of the machine, remove the the hose that connects to the bottom of the tub and the other end that connects to the pump. feel inside the tub for any obstructions and look into the pump for any obstructions.
Jul 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune 7500 front load washer will not turn on when the AC or heat is running
Check voltages at the outlet. My guess is that you are on the HVAC circuit, and the Neptune is more sensitive than your hvac equipment. Also check that the neutral is about the same potential as the ground.
Jan 02, 2007 | Maytag Neptune MAH7500WH Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
