Question about Projection Televisions
Black wave like line on the tv screen
I just bought a 50" RCA DLP tv. It has a black wave like line that goes across the whole bottom part of the screen. What is this and can I fix it?
  • 1153 Answers
SOURCE: half black screen on projection tv
Sounds like the vertical area like Output, but I would look for bad caps first and resistors. In this area
Posted on Sep 14, 2007
  • 5138 Answers
SOURCE: RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Posted on Feb 17, 2008
SOURCE: Samsung DLP vertical black lines
I did some reading on this. They said its caused by a faulty DMD board. I understand it's costly... around $700 to replace. Still looking for a cheaper avenue...
Posted on Aug 30, 2008
  • 927 Answers
SOURCE: Many thin black horizontal lines on my Hitachi Ultravision 50" TV
Good Day, LDS also;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Posted on Sep 06, 2008
  • 63 Answers
SOURCE: vertical black lines on my 50" Samsung DLP TV
You need to replace the digital board
Posted on Sep 03, 2009
  • 5138 Answers
SOURCE: 50 inch rca dlp tv. new bulb. makes a loud
Color Wheel needs to be replaced. Call
1-866-925-7278 For Part number go to Encompass Parts Distribution they will list part number.
Posted on Apr 28, 2010
0 characters
1 Points
Vertical lines
do you have a cordless phone placed nearby?
i just had that problem, and realised it was because of the phone's frequency (scary!). i move the phone/base away from the tv, and it's fine now.
Oct 10, 2009 | Samsung HLN5065W 50" Rear Projection...
try reseating the dvi cable inside the set
Jun 13, 2009 | Samsung HL-S5087W DLP TV
Samsung DLP 50
check the input board for AVI make sure it is not dusty and that all the connections on the board are good you may have a bad solder point or that board is bad ,also possible video ctrl board
May 31, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung rear projection tv have vertical black linens up and on tv
you have a bad dmd module and it cost around $750-$800
Happend, because a bad soldering connections in that module. Lines will come on and off. Probably 1 day will stay on. For last 2-3 years im seen that only on hlm and hln series. Probably
happens on other models. but, i never seen that.
Is not that hard to replace that module. You have to remove 2 screws from left side and 1 screw from bottom righ side of module and 4 of them
from around dlp unit unpulg all cables ( i think
3 cables ) that it. Same way install new one in.
but you will need to adjust a module position to get picture to fill whole screen.
Jan 17, 2008 | Samsung HLN5065W 50" Rear Projection...
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Projection Televisions Logo
Top Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Projection Television Expert? Answer questions, earn points and help others
