Question about Smeg FAB28
How do I remove Smeg FAB 28 Fridge door,as I have bought a new replacement but it has not instructions
Remove the top of the fridge by removing the two screws on the back of the top and sliding the top to the back. that gives you access to the doorhinges. remove the three screews of the lower hinge, which allows you to remove the door from the upper hinge too. (sorry, non native speaker)
Posted on Feb 12, 2010
My 4 door smeg is making loud high pitch shrill noise with quiet knocking coming from the back of the fridge by the compressor and is very hard to listen to what is it?
you just bought it as in new ---get a technician out under warranty---or new to you but second hand ---get a technician out for a proper diagnosis and a quote
May 30, 2016 | Smeg Dishwashers
Gas leak
first you have to find the leak to see if it can be fixed. use some soapy water and a brush and apply to the fittings and see if it bubbles up if not then you need to check the copper line from one end to the other. Sometimes you can solder it but it is best to let a repair man do that if you don't know how to solder.
May 04, 2014 | Smeg Refrigerators
What s the switches inside fridge
prob green power yellow or orange fast freeze
Aug 12, 2012 | Smeg FAB32 Bottom Freezer Refrigerator
Door and handle problems. Smeg fa311x
sounds like your door is sprung. take door off and lay flat on a table outside of the door down. loosen screws on door liner . screws are hidden under door seal. when all loose not removed make sure door is flat on table. tighten the screws being careful not to move door. reinstall door and it should be ok. this is usually cause be either someone leaning or hanging on the door when it is open. or putting to heavy of items in the door trays.
May 26, 2012 | Smeg FA311X Top Freezer Refrigerator
Fridge/Freezer
Probably be cheaper to get new one, it has probably had the compressor fail or a leak in the cooling system.
Sep 16, 2017 | Smeg FR148A Refrigerator
Top hinge has just broken off my smeg fridge.
found an old smeg at the local junk yard and took of the hinges and other parts... cheapest way.
Mar 16, 2009 | Smeg FAB28NE6 Refrigerator With Ice Box
Smeg Fridge light
What you need to locate is the door switch mechanism for the fridge. These are normally located towards the top of the door and protrude so that when the door closes the switch is pushed in. To find out if you have a problem with the switch just press it when the door is open and the light should go off. The switch itself can appear in various forms either as a protruding rod or a curved plate which pushes upwards against the door side when it closes. If I could draw in this section it could be better explained. But if you look around the inside of the fridge on the side away from the door hinge then you should find something you can push. Sorry to be this vague. If you do need a replacement switch they are normally quite simple to change depending on where they are located, most are two screws, or just a push in type. Hope this has been of some help.
Jul 04, 2008 | Smeg FAB28
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper frdige section is fine but freezer not. I have emptied, kept door shut, turned dial up but no...
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper fridge section is fine but freezer not. I have emptied, kept door shut, turned dial up but no success.
Any suggestions on what the problem might be?
Wouldn't expect problems on a SMEG just 2 years old.
You could have a bad thermostat or the refrigerator could be low on Freon, make sure you clean off the exposed coils on the back of the fridge and underneath to free it from dust and dirt – use some type of a blower for underneath and the coils you can vacuum off or wipe off the coils, if not call a service tech to have a look @ the refrigerator – it might have a bad compressor
Apr 14, 2008 | Refrigerators
Smeg Fab 32 door problem
Remove the lower hinge on the fridge door and pack out using a piece of cardboard resrcew the hinge onto the door, this will resolve the problem Regards Advisor Smeg Agent
Jun 08, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Smeg FAB28 Logo
810 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
