Question about Magic Chef Refrigerators
RE: Model #CTB1923AR new bulb doesn't light interior
RE: Model #CTB1923AR We changed the light bulb but it still doesn't light. Any ideas?
MicrowaveSvc
  • 9098 Answers
SOURCE: GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
SOURCE: cannot find interior light or its switch on Miele H251 oven
so remove metal skin on the right hand side of interior....little pip holds it in place...so shove up.
then just prise glass section gently outwards....4 clips hold this in.
bulb is a PHILIPS 25W X7L
300o H.D.
Posted on Apr 10, 2009
  • 18 Answers
SOURCE: GE profile spacemaker mircoware oven change interior light bulb
Check behind the grill on the front top of unit. you can remove it by takign out a few screws from the top. There may be an access door there, if not unit would have to be pulled down and the case taken apart.
Posted on Dec 02, 2009
  • 65 Answers
SOURCE: Model JVM1790SK 01 Where/how do you change the
This is a pretty bad design, sometimes you can just remove the upper grill and access the light assy. If the panel is to tight to work in to change the light,you get to take the whole micowave down and remove the outer wrapper to change the light bulb. This is also not a standard bulb (part #WB25X10019). You may be able to get one from Lowes or Home Depot actually Sears would be a better bet, otherwise you will need to order one from an appliance parts outlet. Hope this helps and sorry I didn't design the thing I just fix them.
Posted on Jan 24, 2010
Jettal
  • 5 Answers
SOURCE: Frigidaire Model NMER336FS0 How do
Unplug the dryer first, of course. With a putty knife, locate the clips under the front of the main top to release the spring clips. Lift the top and support it open. Disconnect any wire clips that are attached to the front panel, such as the door switch wires or wiring harness. There may be a zip tie attached to the wiring harness that you have to remove simply by cutting it off. On the inside, remove the front panel mounting screws down along the front inside edge of the panel. Pull the front panel up and out to remove. Disconnect the wires from the light bulb, carefully noting which wires go where, and press the release tab to remove the old light bulb housing. Install the new bulb and assembly by inserting it into the front panel and snapping it into place. Reattach the wires. Replace the front panel by aligning the slots at the bottom of the panel with the support clips. Lift on the front of the drum as you snap the front panel into place. Replace the panel screws and reattach any wiring that you disconnected to remove it. Rotate the top back into place, pressing down on the front to secure the spring clips. Plug it back in and voila! Good luck!
Posted on Jul 16, 2011
Where can I get Bulbs and Night lamps collections?
If you want to change the interior design of your home. Then it is the best idea for changing your bulbs and night lamps. You can change your interior design with the help of online sites. There you can get the best collection of bulbs and night light lamps. If you are buying this product in online then, you can get best collections, designs, shapes, and colors also and you can compare all the sites where you can get the best collection of this. You can buy bulbs & night lamps, according to your choice.
Mar 17, 2018 | Cars & Trucks
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
Maytag refrigerator lights won't work
the bulbs may look good but try a new one or just try tighting them into the sockets tighter. this is a common problem . the rubber prevents the bulb from going in all the way .. silcone grease on the bulb base.. mm
Dec 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
How do I change the light bulb in the oven
You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights use a universal 40 watt appliance bulb.
Apr 24, 2009 | Philips Ovens
Cannot find interior light or its switch on Miele H251 oven
300o H.D.
Apr 01, 2009 | Ovens
Changing interior lights for 1999 Audi A4 Quatro.
These guys have some cool interior xenon bulb kits - take a look:
http://www.xenonfactory.com/products/interiorlight/audi.htm
Jan 30, 2009 | 2006 Audi A4
Jun 03, 2008 | GE JES1289SK Microwave Oven
Interior light
Hi. I've seen this situation on this model. The bulb is not screwed in all the way. You think it is but it is not. If it still doesn't work, get new bulb. Sounds like you got a couple bad bulbs. Good Luck, Mack
Mar 29, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Open Questions:
Refrigerators Logo
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
