Question about Bosch Logixx WFT 2806 Front Load Washer/Dryer
Bosch wae24442 error code f:34
What does it mean???there is no problem description in manual.
3 Suggested Answers
  • 414 Answers
SOURCE: Bosch 500 washer won't finish rinse cycle. Flashing error code13
Timed out on drain cycle, basically you either have an outlet blockage or something is trapped in the pump, you can check the pump by opening the bottom right flap on the front panel,manually emptying the w/m and checking the pump filter for coins etc. Also, check the outlet isn't blocked.
Good Luck.
Posted on Jul 12, 2010
  • 6277 Answers
SOURCE: I have a Bosch Logixx
Same as 'F16', 'F34' stands for 'door lock (fault)' ;-0)
This is indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Sep 15, 2011
Testimonial: "Thanks - the engineer is coming later today. "
My Bosh 24ES has error code 14 what does this mean and can I fix it
The year 2009 Bosch 24ES manual does not show error code 14.
Your manual may be different.
Call Bosch 1-800-642-3111
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Bosch-GWH2400ES.pdf
Don't forget to read the product manual for required yearly maintenance, and performing this maintenance will eliminate many common error codes.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 09, 2012 | Water Heaters
My bosch tankless water heater is flashing ae
Before calling service technician, open following links for Bosch error codes, and contact information, and possible product manual for your model, etc:
http://waterheatertimer.org/pdf/Bosch_EA_error_code_troubleshooting.pdf
http://waterheatertimer.org/pdf/Bosch-GWH2400ES-error-codes.pdf
http://waterheatertimer.org/pdf/Bosch_A4-E4_error_code_troubleshooting.pdf
Error code AE is not shown, but error EA means "burner flame not recognized by control unit when water is flowing"
There is also error A3 and A3 E3: jumper connection is not correct
Sep 26, 2011 | Bosch & Tankless LP Hot Water Heater
My tank is flashing ae on it
Sep 26, 2011 | Bosch Water Heaters
I have a Bosch Logixx 8 washing machine showing error code 34. What does this mean?
John C
Sep 15, 2011 | Bosch Washing Machines
No hot water at all when I turn on the hot water faucets nothing nomad I would hear the burner kick on but nothing what so ever
Before calling service tech, open following links for Bosch troubleshoot resources including phone support, error codes, possible manual.
No error code can mean PC board failure, or plumbing problem
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Aug 13, 2011 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Engine shut off willnot crank after heating up geting code 34
DTC - 34 MAP Sensor Circuit Error (Signal Low Indicating High Vacuum)
The ECM uses the Manifold Absolute Pressure (MAP) sensor as an indication of engine load. High voltage would indicate low engine vacuum and higher engine load. Low voltage would indicate high engine vacuum and lower engine load. The ECM uses the information from this sensor to help calculate fuel delivery and spark timing.
Fault Code Description:
* 34 - MAP sensor circuit error (signal low indicating high vacuum)
Symptoms:
* Poor engine performance
* Engine running lean (not enough fuel, hard starting, lack of power)
Common Problems:
* GM MAP sensors do not commonly fail
* Due to erratic engine vacuum, other engine performance problems can cause a code 34 to set
Good luck (remember to rate this answer).
Mar 20, 2011 | Buick Riviera Cars & Trucks
BOSCH WAA24270GB error code 0 and 2 backwards rr
Press START button over 10 second, its working for me
Apr 09, 2010 | Bosch Washing Machines
Error Code
open the thing up and locate the service manual. once located it should list what that error means. alternatively call bosch and ask them.
Aug 25, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Computer codes 34 & 35
You can find out at a part store by either asking somebody or looking through a Chiltons/Haynes book on your make, model, and year.
Jul 08, 2009 | 1990 Pontiac Grand Prix
Error Code 63 on Phillips Plasma - what does it mean?
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Mar 30, 2009 | Philips Televison & Video
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
379 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
