Question about GE GSS25LGP Side by Side Refrigerator
GE GSS25LGP SIDE-BY-SIDE WON'T FREEZE. NO FROST. FRIG SIDE OK.
LIGHT IN FREEZER IS ON, WILL NOT FREEZE. DOOR WAS LEFT AJAR TWO DAYS AGO FOR APPROX 8 HOURS.
  • 725 Answers
When the door was left open, the t-stat burned itself out trying to adjust the temp. You will also need a new timer, too, as the timer burned out before the
t-stat went out. Give us a call at 972-859-0929 and we can make sure we get the right parts out to you right away! We look forward to working with you and hope to hear back from you real soon. :>)
Posted on Oct 05, 2009
Refrigerator is staying at 50 degrees, will not get any cooler
May be your computer board, not turning on the defrost heaters in the freezer section. The freezer will eventually get warm too. Are you getting frost build-up on the rear wall of the freezer? If you are, you can temporarily solve the problem by turning off the whole refrige for a day and open up the freezer door- put towels on the floor under the freezer doors. Then turn it back on - mine worked fine again. I am currently waiting for a computer board replacement. It is behind the metal plate on the back (outside) of the cabinet. Good luck.
Sep 28, 2009 | GE Profile PSW26P Stainless Steel Side by...
The freezer is not freezing anything on my GE GSS 25 LGP side by side.
Do you notice frost on the rear wall of the freezer section 1 foot from the bottom ? If so , then defrost problem . If not , probable board problem .
Jul 17, 2009 | GE GSS25LGP Side by Side Refrigerator
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
We left the frig door ajar for 6 hrs, now the frig isn't working but the freezer is... where is the reset button? Thanks!!
Hi, No reset button. Check and make sure the evaporator fan motor inside the freezer is running. While checking that, look and see if there is any frost build up on the rear panelin the freezer. Please let me know if any of these are the case so I can asist you further.
Thanks
Vic
May 23, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Freeze will not freeze.
I had a similar problem. The frost in the back is an indication that your coils are frozen. This could be from food packages falling out of the freezer drawers in the back and blocking the air circulation vents or maybe the freezer door was not closed completely and letting moist/humid air in and freezing the coils.
For me it was the first problem listed.I had to completely empty the freezer and Frig. and take the back panel off in the freezer. There you will see the coils and lots of ice!
1. Remove all items from the frig. and freezer and unplug frig.
2. Pull all the freezer drawers out.
3. On my GE side by side I took the light cover off and removed the bulb. There you will see two panel screws. Remove the screws.
4. Now pull out the mouldings on each side and you should be able to remove the panel.
5. Take a hair drier and completely defrost all the ice from the coils.
Be sure to keep plenty of towels handy for all the water mess. Remember to keep an eye on the drain tray in the back of the frig. and use a sponge to collect the water that will build up.
Hope this helps!.....
Woody
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
FRESH FOOD SIDE OF FRIG NOT COOLING
i would take the back freezer panel off and see what kind of frost pattern your coils have.they may be frosted over and the begining of a defrost problem.
Mar 11, 2009 | GE GSH22KGM Side by Side Refrigerator
Freezer only freezing to 20 degrez
If the door was left ajar for any extended period frost has built up on the cooling coils. A complete defrost of the freezer should take care of the problem. Normally a frost free system will clear the ice from the cooling coil when the defrost time cycle happens. However frost may have built up in areas where the heaters can not readily remove it in a normal defrost cycle and shutting the unit down with the door open for about 24 hours should clear it out.
Nov 27, 2008 | Freezers
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
GE GSS25LGP Side by Side Refrigerator Logo
109 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
