Question about HP DeskJet 5550 InkJet Printer
My printer will not stop printing wing dings when I try and print a document.
  • 630 Answers
Either you've somehow interrupted the print and it's thinking that the information is text or you have the incorrect printer driver. Delete everything from the print queue rebott the printer and computer. If it still happens it's the driver.
Posted on Oct 11, 2009
Printer will print a document but when it reaches halfway it stops printing. Only way to finish printing the document is to restart my pc. Why does this happen? Can this problem be resolved?
When you restart your PC does the printing continue from where it had abruptly stopped printing or does the printer print a fresh copy .
In any case the clean the Print Cartridge Carry Assembly Mount Rod and try freeing up more space on your PC hard Disk for spooling the print data
Jun 28, 2015 | Lexmark X2650 All-In-One InkJet Printer
Why can't I print to my Ricoh Aficio SP C430DN from my Macbook Air?
You probably have a conflict between the paper size the machine knows is loaded and the document size being specified for printing on. Your Airbook is probably trying to send a document on a paper size the printer doesn't have. Net result is a document stored in the print queue that stops anything else being printed. Go full system reboot and clear out any and all waiting documents before trying again.
Sep 08, 2014 | Ricoh Aficio SP C430dn Laser Printer
Lexmark interact S605 has document blocking any further printing and even when I have unblocked previously the next document still blocks
If you're having problem with print jobs getting stuck in the print queue, it could be due to your computer's print spooler service not running. Try the steps below to fix the problem:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Feb 09, 2012 | Lexmark Interact S605 All-in-One Color...
MY LASER PRINTER KEEPS PRINTING WING DINGS
You need to go into the document or driver and select a new font.
Normally, this is a driver issue because the driver will control what fonts are selected on the hardware.
Sometimes, however, the printer's default font has been changed. This will cause the same problem. Check the printer properties and make sure you have the correct font selected.
Oct 20, 2010 | HP DeskJet 5550 InkJet Printer
I started to print a document and noticed it was 18 pages and canceled the printing. Now the printer won't print and the button next to the on/off button just flashes when I try to print something. What do...
I'm not sure why your printer stopped in the first place, but one reason why it won't print is because the print queue is blocked with old document requests.
Try going into your printer properties and remove all documents listed in the print queue.
(Start - Printer/faxes) - default printer - RMB - Properties).
May 16, 2010 | HP DeskJet 932c InkJet Printer
I keep getting the message that my canon mp360 is off-line when I attempt to print.
This could be a couple of things but this is the quickest easiest fix so we will try this first go to start then go to your control panel go to printers and faxes once there you should see your printer name right click on it and make sure that it says use printer offline in the drop down menu if it says use printer online left click on use printer online and that will most likely fix your problem if you have done this step and still having problems turn your volume up a little unplug your printers usb cable you should hear some dings if not its ok now Plug your USB back into your computer wait a couple of seconds you should hear some dings try printing something se if it works (you may or may not hear dings depending on your volume settings) if it's not printing or dinging take the usb plug back out the back of your computer and try another usb port if you still hear no dings and it's still not printing switch usb cords it is likely that the cord is bad
Nov 21, 2009 | Canon MultiPASS MP360 All-In-One InkJet...
How do you clear que on a c6300 photosmart
Windows XP Operating System
Restart the Print Spooler device
  1. Open Administrative Tools.
  2. On the Windows taskbar, click Start , and then click Control Panel .
  3. Click Performance and Maintenance . NOTE: This step is not necessary in XP Classic View.
  4. Click Administrative Tools .
  5. Double-click Services .
  6. Click Print Spooler .
  7. Click Stop to stop the Print Spooler.
  8. Click Start to restart the Print Spooler.
  9. Click OK .
  10. Restart the computer.
  11. Try the print job again.
Manually clear the print queue
  1. Return to the Printers and Faxes folder that you opened in the previous steps.
  2. Right-click the name of the product, and then click Open .
  3. Click Printer , and then click Cancel All Documents .
  4. Click Yes to confirm the action.
  5. If documents remain in the print queue, restart the computer.
  6. Try printing again.
Windows Vista Operating System
  1. Return to the Printers folder that you opened earlier in this document.
If the issue continues, proceed to the next step. Restart the Print Spooler device
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), click Control Panel , and then click Administrative Tools .
  2. Double-click Services .
  3. On the User Account Control window, click Continue .
  4. Click Print Spooler .
  5. Click Stop to stop the Print Spooler.
  6. Click Start to restart the Print Spooler.
  7. Click OK .
  8. Restart the computer.
  9. Try the print job again.
Oct 03, 2009 | HP Office Equipment & Supplies
Printer stopped working
Turn printer on and off if that doesnt work then ust restart, sometimes things get stuck in the queue.
Apr 24, 2009 | Lexmark X1150 All-In-One InkJet Printer
Will not print after turning printer off
I used to have that same problem what i suggest doing is restarting not only the printer but your computer aswell. That seemed to solve the problem for me
Oct 15, 2007 | HP LaserJet 1020 Printer
HP DeskJet 5550 InkJet Printer Logo
132 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
