Question about Archos 604 WiFi Digital Media Player
Usb connection trying 2 connect 2 usb when connected it tells me buttons enabled so its only charging.i clicked on pc hard drive
Hub is not strong enough connect to computer usbs then rebot
Posted on Jan 07, 2008
Pc does not recognize external drive
External hard drives are plug-and-play devices used to store music, video and data files.
Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use. If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected. Hope this helps.
b>
Jan 07, 2013 | SmartDisk Verbatim 96867 2 TB External...
Portable external hard drive
Greetings,
It's the USB port on that computer.
Try all USB ports and make sure you got it connected DIRECTLY.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 23, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Tip
How to Back Up Trial Software
<p>The free trial software gives the user the ability to evaluate a program before they buy. If you have a free version on your computer and want it back, you can connect an external hard drive or flash drive to do. The process can relieve headaches, if your computer crashes or gets infected with viruses.<br /> <p> <br /> <p>1. Connect your external hard drive or flash drive to your computer via a USB port. Click the Start button and click on "Computer" option on the menu. Click on your external hard disk or flash drive icon in the menu. You can use this window.<br /> <p><br /> <p>2. Click the Start button and click "Search ". Enter the name of the test software that you store in the search bar and press Enter.<br /> <p>3. Transferring files to display in the search window on the external hard disk or flash drive. A small window with a progress bar will tell you how long does it take to transfer files appears.<br /> <p><br /> <p>4. Click on the My Computer icon on the Start button when the transmission is complete and right click on your hard disk or a flash image. Click the "Eject" option. Remove the USB cable from the USB port of your computer to your software.<br />
on Jun 21, 2011 | Computers & Internet
Imation 1TB USB external Hard Drive .....unrecognized in Windows Both in windows7 and XP.
External hard drives are plug-and-play devices used to store music, video and data files. Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use. If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
Jan 07, 2013 | Imation 1TB Cartridge (IMN27957) Hard...
My pc is not reading the external drive. My previous shortcut is not responding. I have tried multiple usb connections.
b>
Dec 16, 2012 | Computers & Internet
How to download music from pc to psp
Hi sexysue38,
Based on your concern, I suggest trying the following steps:
1. Connect the PSP to your PC with a USB cable.
2. Press the "home" button on the PSP
--> at the lower left of the screen you can see the home button.
3. Use the left-right directional buttons to find "Settings", then the up-down buttons to find "USB Connection" on the PSP.
4. Press the "X" button, your PSP should display "USB Connection".
5. Please wait until your computer tells you that a new USB device has been connected, then show you a new generic hard drive, usually E: or F:
6. Click on the drive letter that corresponds to the PSP unit.
7. Now create a new folder on that drive and name it "psp".
8. Within the new "psp" folder create another folder, and name it "music".
9. Copy your desired mp3 files into the new "music" folder.
10. When you're done copying your desired music tracks, press the "O" button on the PSP to get out of USB connect mode.
To play the music, Use the left-right arrows to move to the music area, then the up-down arrows to find "Memory Stick". Chose that folder by pressing the "X" button again, and you should be able to find all your favorite music!
Hope it helps,
Thank you for using FixYa.
Feb 03, 2011 | Sony PlayStation Portable (PSP) Console
HOW TO DOWNLOAD PSP GAME
Hi imohhamed,
7. Now look for ISO folder then copy your desired game (ISO file) into the folder.
8. When you're done copying your desired games, press the "O" button on the PSP to get out of USB connect mode.
9. To play the game, Use the left-right arrows to move to the game area, then the up-down arrows to find "Memory Stick". Chose that folder by pressing the "X" button again, and you should be able to play all your favorite game!
Hope it helps,
Thank you for using FixYa,
Feb 02, 2011 | Sony PSP (Piano Black)
Cant download game on psp
Hi sprasar,
Based on your concern, I suggest trying the followingsteps:
3. Use the left-right directional buttons to find "Settings",then the up-down buttons to find "USB Connection" on the PSP.
4. Press the "X" button, your PSP should display"USB Connection".
5. Please wait until your computer tells you that a new USB devicehas been connected, then show you a new generic hard drive, usually E: or F:
7. Now look for ISO folder then copy your desired game (ISO file)into the folder.
8. When you're done copying your desired games, press the"O" button on the PSP to get out of USB connect mode.
9. To play the game, Use the left-right arrows to move to the gamearea, then the up-down arrows to find "Memory Stick". Chose thatfolder by pressing the "X" button again, and you should be able toplay all your favorite game!
Hope it helps,
Jan 20, 2011 | Sony PlayStation Portable (PSP) Console
PSP Not Connecting to PC via USB
Hi rupasam,
1. Before you plug it in make sure the PSP is in USB connect mode.
--> Also make sure the Memory Stick PRO Duo has been formatted for PSP. If it's not this is how you do it:
On the main menu, scroll all the way left to the "Settings" menu. Then select "System Settings." Then scroll to "Format Memory Stick" and press X.
2. Connect the PSP to your PC with a USB cable.
3. Press the "home" button on the PSP
4. Use the left-right directional buttons to find "Settings", then the up-down buttons to find "USB Connection" on the PSP.
5. Press the "X" button, your PSP should display "USB Connection".
6. Please wait until your computer tells you that a new USB device has been connected, then show you a new generic hard drive, usually E: or F:
7. Click on the drive letter that corresponds to the PSP unit.
Hope it helps,
May 29, 2010 | Sony PSP (Piano Black)
My archos wont connect to my computer
Depending on which settings you have on the archos 5 or 7 itself, (you can select "Windows Media Player mode" or " Hard drive/PC/Mass Storage mode" when you choose enable USB a new letter will appear as shown below (if you are on XP - same goes for Vista):
Hope this helps?
Jul 10, 2009 | Archos 5 Internet Media Tablet
Archos 604 WiFi Digital Media Player Logo
54 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
