Question about Hotpoint Aquarius WF000 Front Load Washer
My hotpoint wf340 lights are flashing (all of them).
Hi, I have the same problem, area around c10 r20 charred and c17 blown. I will change the capacitor on c17 did you change any others whilst working on it? and also which chip did you replace and what did you replace it with?
Posted on Jul 25, 2010
  • 1 more comment
  • bazsutto Oct 26, 2010
    Thanks for the info Fozzy.
    Removed the PCB in my machine and C17 was blown. Replaced the cap. and back in business. Saved splashing €100 on new board!!!
    Thanks
    Barry
  • willocon Nov 18, 2010
    Hi there I have the same problem. Can you tell me the part numbers (radionics or farnell) for c10, r20 and c17?
  • bazsutto Nov 19, 2010
    Just try C17 first, If you look on the side of the cap, you will see the info required. I think you need a 680uF, 105degree, 10Volt electrolitic Capacitor. As it is a capacitor, they have a large tollerence (5-10%), you can use a similar value one. I used a 1000uF, 105 Degree, 25Volt (can go a larger voltage) one and it works perfect.
I had the same problem.
If you are confident, remove the circuit board (power off) from the rear of the washer take not on where the connectors go!!
Look to see if the area around c10/r20 is charred and c17 is blown.
I replaced the chip plus the capacitors and cured the problem, all for about £15.
Posted on Nov 18, 2009
Wf340 door locked sign flashing ? will not start the program?
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Apr 08, 2011 | Hotpoint Washing Machines
Manual for hotpoint wf340 aquarius
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WF100toWF745_Install_19504953203.pdf
Download this manual for free
Sep 20, 2010 | Washing Machines
Where can i get instructions on how to use my hot point aquarius wf340 washing machine
You can retrieve a complete owners manual if you go to the manufacturers site, under"support" you'll see downloads, type in your model # and it will come through as a type "pdf." file to keep on your computer forever.
Sep 07, 2009 | Washing Machines
My Hotpoint washing machine wf340 will not complete a wash cycle it just stop then the lights start flashing next to the mini load button + reduced crease button and the on off button pls help
You have a bad printed circuit board (PC board). You will have to replace. I would rate this job a 4 on a hardness scale from 1 to 10. You will need your model number located on the back of the console toward the top. Go to this site and enter your model number. You can order it with a credit card 24/7 http://www.partselect.com/
Please rate this solution if helpful.
Aug 20, 2009 | Washing Machines
Error code on my Hotpoint Aquarius WF240
my hotpoint Aquarius wf340 when switch on 5 secs later on/off button flashing along with mini load lights. could u tell me the error codes for this machine?
Apr 04, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Wash enhance & on/off flashing
The only time the lights kept flashing on my Hotpoint machine was when the outflow pipe going into the ubend was blocked,
Check for blockages, but make sure that you have a bucket or pan ready to collect the water flow.
I hope this helps
Nov 24, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wf340
First remove the filter (if you can do this easily) - place a roasting pan under it to catch the water.
If you cannot get to any filter, remove the rear pipe from the waste pipe, and check it is not obstructed.
If it looks good enough, try a hot wash with 1 cup of soda crystals. This should clear any accumulation of grease in the pipes.
If still no good, you may have to open up the machine to clear any internal filter before the pump, and check pump vanes are still intact.
Nov 05, 2008 | Kenmore 13202 Top Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
1,623 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
