Question about HP 5590 ScanJet Flatbed Scanner
Begins scanning...then stops in middle and won't complete scan. I'm in windows 7 with HP Scanjet 5590
    President:
  • 1,564 Answers
Go into your "printer properties" and make sure that someone hasn't inadvertantly changed the page settings.
Posted on Oct 05, 2009
SOURCE: HP ScanJet 5590 ADF doesn't engage
cannot possible to install in vista using the CD of scanjet 5590
Posted on Apr 25, 2008
bandana_gyrl
  • 181 Answers
SOURCE: HP ScanJet 5590 and OS 10.3.9
I would do a manual uninstall and make sure to do the device utility at the end and follow the directions step by step from this link.
Redownload the drivers and make sure they are for 10.3.9 and the full feature software to make sure the right drivers are going to be installed.
Also I would unplug the unit while it is on and plug in directly to the wall to make sure not a power issue. The printer does not share power well and pulls it in large amounts - when it can't get it it throws little power fits and sometimes will not turn on at all or it gives error messages.
Posted on Feb 28, 2008
mohanchennai
  • 490 Answers
SOURCE: Blank Scan from HP Scanjet 5590 Flatbed Auto Feed
Scanning is possible in 'Text' mode and 'Picture' Mode. In text mode, which is simple 'Black & White", this can happen, particulalrly if the text is in color. Either you increase the contrast settings or scan the document in Grey/color and convert it to B&W using the software. By this you need not check if there is output!. ( I am assuming that otherwise the scanner is performing okay). File size in B&W is very small as compared to Grey/color.
S. Mohan
Posted on Apr 06, 2008
SOURCE: Hp scanjet 5590 error in
I downloaded the following files from HP's website
setup_full_5590
setup_emc_5590
col10862
cit207355-hpcom-patch-v8
hpinstantshare
and followed the procedure that i found on the web at hppt://hpanswers.blogspot.com/2008/03/unexpected-internal-error-has-occurred.html
wich give full instructions on how to cleanly remove the hp software and what files you need to run to help fix the problem.
this is a fix but it is has not got my scanner working the way that it used to but it is working a lot better that it was.
Thanks
Sproket
Posted on May 01, 2008
SOURCE: Hp5590 Front Panel Scan buttons does not work
thsi is it
Posted on Nov 03, 2008
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ...
    h30434.www3.hp.com > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
HP SCANJET 5590 IS SCANNING VERY SLOW. ANY WAY TO INCREASE SPEED
scan at a lower resolution .
Maybe increase virtual memory of p.c. in Windows o/s
Aug 09, 2012 | HP 5590 ScanJet Flatbed Scanner
Is there any software for scanning can use with this scanjet 5590 with win 7...it seems i cant install hp photo and imaging software on my win 7 machine..help me..
Try downloading the latest software from HP: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=377691&lang=en&cc=us&taskId=135&prodTypeId=15179&prodSeriesId=377689
They list Win7 versions of the full software issued Dec 11, 2009, as well as just the basic drivers. However, if you installed the scanner using the generic drivers in Win7, you should be able to scan using Windows Fax and Scan or Paint. (In Paint you bring in the images as if they were on a camera.)
I hope this helps.
Feb 09, 2010 | HP Scanjet 5590 Flatbed Scanner
HP Solution Center does not recognize the scanner anymore... We are operating on a Windows 7 system... the drivers had to be downloaded from the internet because the cd that came with the printer was for...
I had the same problem and solved it. I was using HP Solution Centre to run my HP Scanjet 5590 on Windows 7 Pro 64 bit without problems. Then I ran the scanner using Windows Fax and Scan, but didn't like it, so went back to HP Solution Centre - whereupon the scanner was not recognised.
After hours of reinstalling software etc etc, without success, I suddenly noticed four device icons on the left hand side of HP Solution Centre. These were labelled (when hovered over with the mouse) hp scanjet 5590, hp scanjet 5590 #2, hp scanjet 5590 #3, hp scanjet 5590 #4. Only the top icon was active, but when I clicked on any of the four it moved to the top.
Clicking on hp scanjet 5590 #2 gave me a working installation once more - problem solved. No doubt the multiple icons arose from my desperate attempts to try different USB ports.
Feb 02, 2010 | HP Officejet 6500 Wireless All-in-One...
Scanjet 5590 wont scan straight images
I have the same problem. It's very frustrating!
Sep 14, 2009 | HP Scanjet 5590 Flatbed Scanner
HP 5590 - cannot scan and save doc directly to jpeg format
I need the scanned documents be saved as pdf in HP scanjet 5590
Apr 27, 2009 | HP 5590 ScanJet Flatbed Scanner
HP Scanjet 5590 nothing showing in Scan to box
go to control panel and start using the scanner from their it may work
Jan 12, 2009 | HP Scanjet 5590 Flatbed Scanner
Hp director
uninstall and remove all the icons from your PC first than reinstall the driver from CD and run complete setup it works.
Feb 18, 2008 | HP 5590 ScanJet Flatbed Scanner
HP 5590 ScanJet Flatbed Scanner Logo
936 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
