Question about Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater
Remote Control Problem
Our remote control indicates that the fan is off when the fan is actually operating. The only way we can get the fan to turn off is if we turn it off at the swithch, fan and light both. We've replaced the batteries in the remote but the fan still won't turn off or change speeds.
  • Josh F16 May 06, 2008
    My fan (model 55295) will not turn on. I have the remote and two swicthes on the wall for the fan and the light. I think the remote needs to be programmed - is there a code book for it? I did not install the Hampton Bay fan/light
    Problem Solver:
  • 9 Answers
You have dip switches in the remote control and in the receiver . They are probaby not set the same.You'll have to open the canopy at the ceiling to check the receiver. Hope this helps
Posted on Feb 15, 2009
You have a ground somewhere ... check the wiring. Most likely the ground shorted the signal sender.
Posted on Oct 03, 2008
  • 4 Answers
I had this problem. One day everything worked. The next day the fan ran at 1 speed and the remote didn't turn on the light, change fan speed, nothing. I changed batteries on the remote - no good. As you should know, the dip switches on the remote and on the fan have to match - which makes the remote and the fan on the same radio frequency so they can talk to each other. (They let you change radio frequency so that you don't control a similar fan down the hall as well as the one in the room that you intended to control.) Anyway, come to find out from the fan guy at Home Depot that sometime the dip switches on the fan "fall" out of place leaving the remote unable to talk to the fan. Sounded crazy, but sure enough one of the dip switches on the fan wasn't tightly in place. Once all the dip switches were tightly in place (with the fan dip switches matching the remote dip switches) everything ran fine. To change the dip switches on my fan that meant uninstalling the fan from the ceiling and taking the big top cover off to expose the dip switches.
My fan: Hampton Bay 54 In. Brushed Steel with Remote Model 55295
Posted on Sep 17, 2008
Fan buttons work the light. Light button does nothing. No button causes fan to operate. What's wrong?
If there are pull-chain switches on the fixture, their operation may have caused remote control to fail. Turn off power at the source, pause for a few minutes, and turn on power. Either fan or light control, or both, may work. If not, you will have to figure out which pull-chain operation makes things right again. To avoid future problems, disconnect the pull chains at the link so only the remote controls operation.
Apr 17, 2016 | Hunter 27185 Fan Speed and Light Control,...
How to operate fan without remote controls
Hi, Your actual question was about overriding the circuit and not using a remote. What you want to do is hook up a wall switch
Your question actually is answered on this page
Look under converting to 3 speed - number 4 - it cannot be done unless your fan has a remote bypass switch.
Troubleshooting Ceiling Fan Remote Controls My Remote is Not Working...
Aug 08, 2014 | Savoy House Televison & Video
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
Kenmore remote control ceiling fan Model 689.116700 with variable breeze setting. Fan has always worked great but has stopped running and will not turn on. The simple things have been checked and the...
How about the remote can they be replaced? I just got the same fn from a friend that has been in box for 20yrs. All works fine but Im worried about remote going bad.
Jun 01, 2011 | Hunter 52" Ceiling Fan With Light And...
How do I set up a ge universal remote control on a sony television Stopped working changed the batteries too.
Hi! For me to be able to give you the correct code for your universal remote control, I actually need the model number of your remote control because there are GE remote controls that need a 3digit code and there are GE remote controls that need a 4digit code. But since I don't have the model number you may just try these codes and the instructions below.
4 digit code for Sony are:
0128, 0013, 0002, 0071, 0380, 0152
3 digit code for Sony are:
002, 006, 013, 071, 128, 380
1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
2. Press and release the desired TV button. The red indicator blinks, then stays lit.
3. Enter the 4 digit code or 3 digit code from the list above.
Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
4. With your TV on, press ON/OFF. If the TV turns off, no further programming is required. Note: If some buttons do not operate your TV, try one of the other
codes.
Jun 14, 2010 | Televison & Video
Track lighting remote control similar to that of ceiling fan?
Yes, but the remote operates on the switch that turns the lights on and off. Lutron has this kind of technology and it is really cool. I have it all over my house and I don't even have to go room by room turning lights off; I just push a button from my bedroom. Along with a single remote that can be used with each switch in your house, you can program a house remote that controls the lights and ambiance of every room.
Jun 03, 2010 | Universal Remote Control Hampton Bay...
Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater Logo
607 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
