Question about GE Refrigerators
I HAVE A GSS22SGRB SS REFRIGERATOR AND THE WATER WILL NOT DEPENSE BUT IT MAKE ICE FINE
  • 833 Answers
SOURCE: GSH25JSRF SS Issue with water/ice delivery
Are you actually getting water into the fridge? Has the line frosted? You may have to defrost and make sure your freezer is not set lower than 5 degrees F.
Posted on Dec 21, 2007
SOURCE: GE Monogram ZISS480DMCS Ice Maker Problem
The water solenoid valve should have 120v going to it. (You will need a multimeter to chk this). You will need to also chk. for proper ground when verifying the 120v. If you get 120v on each of the pin clips, then your plug is not properly grounded, which means that you need a new ice maker circuit board. This is located in the in dispenser (front panel opens).
Posted on Jan 24, 2008
SOURCE: No water flow
I had the same problem.  The water lines in the freezer door had frozen up.  I defrosted the freezer, and the water flows great now.
Posted on Jan 24, 2009
  • 19 Answers
SOURCE: Can't unlock ice water depenser on maytag side by side
On most brands all you have to do is hold the lock button until it unlocks.
Posted on Jun 10, 2009
aasc
  • 1606 Answers
SOURCE: My GE SS Side by Side Refrigerator is not
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , to help keep this from happening again , if , the water line is frozen . Pt # WR49X10173 .
BB ..... refrigerators are not your AoE .
Posted on Dec 16, 2009
When I press the ice depenser lever nothing happens no noise at all and no ice in glass.
Your dispenser is probably broke. You should get someone to come repair it for you. I have had something similar happen to me before.
Nov 27, 2014 | Refrigerators
I have mold forming on the ice depenser that's next to the water depenser. Is there a way to remove that piece so I can clean it?
with out seeing the brand or model i have to be pretty generic but their should be a removable grate so drips when dispensing ice or water that can be easily lifted and wiped out, if not place a paper towel at bottom of dispenser asm. to catch drips
Jul 23, 2011 | Refrigerators
Jun 10, 2009 | Maytag MSD2756G Side by Side Refrigerator
The refrigerator by itself activates the water or ice dispensing
could be the water valve or water switch (depense switch)
Apr 01, 2009 | Refrigerators
I have a Frigidaire refrigerator Model FRS6L9EFSS0
Hi
When an ice maker is producing ice poorly--when it produces just a few cubes or crushed ice , or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please revert for further assistance and Do rate the solution if found useful.
Thanks
Rylee
Mar 18, 2009 | Refrigerators
Ice tray freezing
the water inlet valve may not be closing properly due to dirt or some mechanical problem in it. u can clean and try
Mar 10, 2009 | Kenmore 50522 / 50524 Side by Side...
Hotpoint refrig makes ice but no water will come out
Make sure that the water filter is the right one and that it is pushed all the way in. If that is correct than There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test the water solenoid with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad.
Dec 28, 2008 | Whirlpool GD2SHGX Refrigerator
Water stop depensing ice work but no water
I had the same problem. I found the answer on this forum.
The water line could be frozen in the door. Need to 'thaw' your door.
http://www.fixya.com/support/t1247133-no_water
Copy paste link.
Dec 08, 2008 | Hotpoint HSS25GFP Side by Side...
We have had water leaking on the floor for 3 weeks now. We have checked Ice Maker, water depenser, and even disconnected all sources of water to refrigerator. The refrigerator is a Kenmore.
Check the pan on the bottom of the fridg. the hose could of slipped out, this runs from the freezer section to the pan, when it goes into defrost water goes to the pan
Nov 11, 2008 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
