Question about ASUS Eee 4G Notebook
Unable to system restore computer reports error when trying to switch on system restore
    President:
  • 1,564 Answers
You can try to "System restore" at boot-up. This option will display for a very brief moment at the beging of your boot up sequence. The regular system restore has probably exhausted all previous restore points.
Posted on Oct 05, 2009
I have been trying to load Viber on to my desktop, running windows XP pro. installation aborted near end with the usual error message to send to microsoft ...0xc000001d... My machine has no issues as far...
The 0xc000001d error may be caused by windows system files damage.
There are two (2) ways to fix 0xc000001d Error:
Advanced Computer User Solution (manual update):
1) Start your computer and log on as an administrator.
2) Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
3) In the new window, select "Restore my computer to an earlier time" option and then click Next.
4) Select the most recent system restore point from the "On this list, click a restore point" list, and then click Next.
5) Click Next on the confirmation window.
6) Restarts the computer when the restoration is finished.
Novice Computer User Solution (completely automated):
1) Download (0xc000001d) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
This tool will scan and diagnose, then repairs, your PC with patent pending technology that fix your windows operating system registry structure.
basic features: (repairs system freezing and rebooting issues , start-up customization , browser helper object management , program removal management , live updates , windows structure repair.)
Nov 02, 2013 | Computers & Internet
My computer won't do a system restore. Why not?
Unless a RESTORE point was SET up when the last installation was done , the system cannot be set to a restore state of an earlier date.
So you will need to reinstall or try with a recovery disc.
Jul 26, 2011 | Sony VAIO® VGN-N160G/W PC Notebook
Installer initialization failed due to following error: Error: @AvgErrorCode_0x0253 %FILE% = "C:\Program Files\AVG\AVG8" @AvgErrorCode_0x0020 how can i remove this avg fault....
try to restore your system to when it works normally..to do this;
Click windows start>pointing all programs>click accessories>system tools>then system restore.. On system restore window tick on "restore my computer to an earlier time" click next then select date and time to when that program works good before the error occurs.. click next then next...wait untill the process complete...click ok after finish..
hope this help, goodluck
Feb 19, 2011 | Computers & Internet
Error: 0xC004D401 an unauthorized change was made to windows The security processor reported a system file mismatch error.
I suspect a program or driver for a hardware device was just installed prior to this error. Best thing to do is to use Windows Restore and use a restore point dated before the first occurance of the error. You may need to repeat this process choosing previous restore points until system is back to normal or you have run out of restore points.
Here's how:
Startup computer and go into safe mode (Press F5 key as computer is starting up but before you see the Windows logo screen).
Open your Windows Vista Start menu, select All Programs, select System Tools, and then choose System Restore.
Use the System Restore Wizard to choose a restore point/date that was created before the error started occurring on your Windows Vista computer.
Revert your system configuration to this same restore point.
If error still occurs and you had other restore points, you can repeat process with older restore points.
If you have gone back several points and still cannot, you may have not choice but to do a full Windows restore. This can result in a loss of data.
If you get to this point, re-post here for instructs on how to possibly save data before doing a full restore.
Bret
1-2-1ComputerServices
Oct 07, 2009 | Microsoft Windows Vista Home Premium with...
Problem With My PC
When did it first start happening?
Do you have restore points activated? Try restoring your machine to an earlier date to see if it fixes the problem.
Feb 05, 2009 | Microsoft Windows XP Professional
Can not even use restore disks
from microsoft below ....
Bug check 0x50 usually occurs after the installation of faulty hardware or in the event of failure of installed hardware (usually related to defective RAM, be it main memory, L2 RAM cache, or video RAM).
Another common cause is the installation of a faulty system service.
Antivirus software can also trigger this error, as can a corrupted NTFS volume.
Resolving the Problem Resolving a faulty hardware problem: If hardware has been added to the system recently, remove it to see if the error recurs. If existing hardware has failed, remove or replace the faulty component. You should run hardware diagnostics supplied by the system manufacturer. For details on these procedures, see the owner's manual for your computer.
Resolving a faulty system service problem: Disable the service and confirm that this resolves the error. If so, contact the manufacturer of the system service about a possible update. If the error occurs during system startup, restart your computer, and press F8 at the character-mode menu that displays the operating system choices. At the resulting Windows Advanced Options menu, choose the Last Known Good Configuration option. This option is most effective when only one driver or service is added at a time.
Resolving an antivirus software problem: Disable the program and confirm that this resolves the error. If it does, contact the manufacturer of the program about a possible update.
Resolving a corrupted NTFS volume problem: Run Chkdsk /f /r to detect and repair disk errors. You must restart the system before the disk scan begins on a system partition. If the hard disk is SCSI, check for problems between the SCSI controller and the disk.
Finally, check the System Log in Event Viewer for additional error messages that might help pinpoint the device or driver that is causing the error. Disabling memory caching of the BIOS might also resolve it.
Sep 23, 2008 | Gateway 7405GX Notebook
Wshtcpip.dll error message
Run a system restore. You may need to go back two or three restore points before it fixes the problem, but the restore should do the trick. Try this, let me know, and if the problem persists, then we'll try a different approach.
Aug 03, 2008 | Dell Inspiron 6000 Notebook
ASUS Eee 4G Notebook Logo
69 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
