Question about ASUS Eee PC 900 Notebook
Its not fully powering up. 2 lights come on and the screen stays blank. it was fine earlier 2day
    Brigadier General:
  • 3,614 Answers
This can be a hardware problem, if you can easily access the RAM memory module of the unit, try to remove it, clean contact, and resit to slot again. If you still have the problem you better get it repaired.
Hope it helps
Posted on Oct 05, 2009
My HP laptop was working fine, and then suddenly the screen went blank. When I reboot, the power light stays on and you can hear the hard drive spinning, but the screen stays blank.
unhook all usb cables and power cable, take out battery. Hold down Power button for 60 seconds, which will get rid of all static electricity. Plug in all cables again and check.
If still facing problem there will be some connection issue inside the lap.
Please let me know whether this works or not.
Dec 20, 2010 | Computers & Internet
ZEN will not power up
First back up all of your music and do this: Turn off the player and make sure it is disconnected from the computer. Then press and hold the play/pause button and turn it on simultaneously. It will then enter recovery mode. Scroll down and select format (all) and let it format and it should work like normal. If it freezes again, then you may need a firmware update.
Apr 29, 2010 | Creative Labs Zen Digital Media Player
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
It will power on but then turn right back off it worked fine yesterday
One of four things happen when these lcd's get power problems. 1. They either go completely dead[no power with no lights] 2. Little green light will blink and go back to red with dtv briefly showing and then the tv screen go blank 3. Same as # 2, but with screen staying blank. The fourth is extremely rare, which is a shorted panel that makes the tv set behave like it's getting no power. All signal a bad tv, and the fourth is not usually repairable, requiring a whole new panel. I hear that power flows thru the panel, so that would explain how sometimes it will short out.
Apr 28, 2009 | Emerson EWL3706 37 in. LCD Television
HP L1706- screen is blank when I switch on
First if you have a extra monitor try to plug it in and see if it works. If not then check your video card. or get into the computer and try and remove and reseat the memory. Sometimes by just doing that can solve the problems
Feb 06, 2009 | HP L1706 17" LCD Monitor
My laptop comes on but the screen stays blank??
Unplug the power, remove the battery and then hold the power button for 30 to 60 seconds. Then reattach the power and attempt a boot. It worked for me! Just shutdown, put the battery back in you're good to go. Worked for me so definitely worth a try.
Good luck
~Phil
Jan 09, 2009 | Computers & Internet
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Viewsonic VA1912WB error says analog signal
I had a Gateway 19" TFT that did the same thing.
Does the power light stay on? If so, you more than likely have "dry" solder joints at the inverters. Take it apart & shoot a little solder on the inverter solder joints. Good as new now. The solder joints dry out because of the high heat generated. This is a very common problem.
Apr 22, 2008 | ViewSonic VA1912wb Monitor
ASUS Eee PC 900 Notebook Logo
27 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
