Question about Roper REX4634KQ Electric Dryer
Roper dryer model: rex4634kq1 The press for "on" button/knob cracked off in my hand. Do I just need a new knob or do I have to consider other parts?
  • 121 Answers
Here is the part yhou will need to complete the job 8274376
Posted on Oct 20, 2009
  • egonzalez912 Oct 20, 2009
    here is the part yhou will need to complete the job 8274376
Rex4634kq1 wiring diagram
There are two thermostats that need to be checked for continuity, the thermal cut off and the hi-limit". If found to be bad, they need to be replaced. Here is the kit you need.Here is a video to show you how to check them.
Oct 19, 2012 | Roper REX4634KQ Electric Dryer
My dryer roper rex4634kq1 is making whining noises what could be the problem?
I would guess it would be the belt that is squeeking or it is a wheel that the drum runs on and its bearings are worn out.
Oct 06, 2010 | Dryers
MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
Roper dryer by maytag press star button here noise but does not start?
you will nead someone to help you to see if you have a bad moter.first open door,with your right hand push in on the door switch.hold the switch in ,have someone push the start switch in and at the same time with your left hand turn the dryer drum clock wise,if the dryer starts than you have a bad moter.the cost of the moter would be 1/3off the cost off a new unit.
Nov 20, 2009 | Roper REX4634KQ Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Seems like it may be overheating.
check also, the fan. there may be lint built up inside the fan blades or housing blocking air flow
not a solution, yet, something to check
Jul 25, 2008 | Roper REX4634KQ Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Roper mod REX4634KQ1- Location of BOTH thermal fuses.
one is by heating element. i can fax you the diagram if you give me fax#
Jan 02, 2008 | Roper REX4634KQ Electric Dryer
Either the heater element is breaking or is loose and getting only 110V instead of 240V.  First I would check the wall outlet with a voltmeter for 240V between Line1 and Line2.  Also check the connections and continuity for the heater element.
Oct 11, 2007 | Roper REX4634KQ Electric Dryer
Roper REX4634KQ Electric Dryer Logo
108 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
