Question about Dell PowerEdge 1800 Server
I believe the ide hdd, which contains the OS and boot function has gone bad. I want to remove the drive and see if I can access the drive as a slave from another computer. How do I get the top of the casing removed so I can access where the drive is contained?
  • 657 Answers
Here's the Guide which will help you to Open the Cover and install Devices
Dell PowerEdge 1800Server Troubleshooting Guide
Posted on Oct 05, 2009
    Scholar:
  • 85 Answers
First you will need the key to the bezel(if its locked). Then the whole front pops off. it snaps off really easy. if you need any more help just look here.
http://support.dell.com/support/edocs/systems/pe1800/en/index.htm
loads of diagrams and procedures.
    Sergeant:
    Novelist:
  • 191 Answers
Remove case screws and access panel side of case. The drive will be in a chassis cage attached to main chassis. Remove power cable and data ribbon from rear of drive. May or may not have to remove a screw to gain access to this cage and release drive. In some cases, there are plastic guides holding the drive. You press on the release and then slide the drive out. If it's in a 5 1/4 bay, you can sometimes slide it out the front panel. If no guides or cage, then there will be two screws on each side of drive that need to be removed to release drive.
Desktop Acer M1641: 1 IDE optical drive+ 1 SATA HDD. When SATA disabled,both drives appear in Bios n boot sequence. When SATA enbled, only optical drive in Bios. When both are present (as said before)...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Hope this helps
May 18, 2011 | Computers & Internet
I have two hard drives in my tower How can I make it boot so that both hdd show in one os And it goes straight to windows
Windows will see both hard disks when Windows opens up.
For IDE/PATA hard drives the boot hard disk (C drive) must contain the Windows operating system and it must be jumpered as the Master drive. The other hard drive must be jumpered as a Slave drive if it is on the same data cable as the Master drive.
After Windows has been installed and this Slave drive has been partitioned and formatted Windows will see this hard drive as D: Drive which can be used as data storage etc.
If you have SATA hard drives you need to connect each SATA hard drive on its own SATA cable/controller.
Apr 09, 2011 | ASUS Computers & Internet
Getting three beeps with my asus m4a785t-m motherboard initializi
Okay, not much else is mentioned about the system so I would assume you have one CD/DVD drive and now two HDDs and your new HDD is still set to factory default of "Cable Select" or CD, if not and the new hard drive is a replacement for a damaged OS (Operating System) drive, then you need to insert the Windows OS Installation disk prior to booting and set the system to check your CD-ROM before checking Hard disks, for the OS.
First off if IDE, you have a ribbon that resembles this [====[========[ the furthest to the right would be what plugs into you motherboard, being the one with the furthest distance between itself and the next plug/connector.The one on the other end is for the Master drive and teh middle one is for Slave.
If only one HDD, then the jumper for the new drive needs to be set to Master and the CD/DVD-ROM needs to be set to Slave.
  • If two HDDs & one CD/DVD Rom, On the primary IDE Controller, set the OS HDD to Master, the CD/DVD-Rom to Slave & put the second HDD on the secondary IDE Controller as Master.
  • If two HDDs & 2 CD/DVD-Roms they must be set up on totally different IDE controllers to cancel out the chance of cross-communication. This happens on some systems because of having two CD/DVD Roms and/or two IDEs. So, we set the OS HDD to Master on the Primary IDE Controller & we set the CD/DVD-Rom to Master on the second IDE controller and the
I would normally say that three beeps from the motherboard itself would be either graphics card or memory problems, normally solved by simply pulling either or both and reseating them. Wear Nitrile gloves (the blue ones) to keep oils and static charge from damaging the components, ground yourself &/or touch the case before and while pulling the components. Check this site for "Post Codes" if the beeps are coming from the MoBo... if you have Award BIOS (should show what BIOS brand when booting up the system)
Award BIOS Post Codes
If three beeps from the system itself, then that would say it can't find the OS... and you might possibly also find an error on the monitor, stating something similar to "no power to monitor".
If you don't have an illustration on your drive telling you what pins are for what when it comes to the jumper, then search google for the drive brand and the word "jumper" or words "jumper configuration" or "jumper placement"
example: Maxtor Jumper configuration
If the system is SATA only (I believe it to have at least one IDE controller unless the board's controllers are all blue & black, to which I see a controller, but can't tell if it is FDE or IDE), then you'll most likely have to enable the SATA controllers in BIOS and set the boot preference/sequence/order as mentioned above, to check the correct disk for the OS, after removable devices & CD-ROM. Should be that order anyway, with floppy seek disabled to save wear on the head.
Hope that was not too much and that it helps!
Apr 15, 2010 | Frigidaire FEQ1442ES Electric Dryer
Controller MSI K8N Neo4 does not work
SHUT DOWN COMPUTER AND CLEAR CMOS BY RESETTING JUMPER ON MOTHERBOARD AND THEN RETURN JUMPER TO NORMAL POSITION OR USE RESET BUTTON. UNPLUG ALL HDD SATA CONNECTORS FROM HDD. BOOT COMPUTER TO BIOS. MAKE SURE ENABLE ALL SATA IS ENABLED, PRESS F10 AND EXIT.YOU WANT TO SHUT DOWN AGAIN. NOW REATTACH SATA HDD AND CONNECTORS AND BOOT TO BIOS AGAIN. NOW HIT F10 AND LET COMPUTER RESTART AND LOAD INTO THE OS. LOGON AND CHECK DEVICE MANAGER..SHOULD BE THERE. IF NOT CHECK MOTHER BOARD WEB SITE FOR BIOS UPDATE. IF BIOS UPDATE DOESN'T DO THE TRICK, SHUT DOWN AND DISCONNECT THE IDE DRIVE, UNLESS IT CONTAINS YOUR OS. TRY BOOTING TO BIOS AND CHANGE ORDER OF 1ST BOOT OPTIONS, HIT F10 AND EXIT AND ALLOW COMPUTER TO BOOT TO OS, THEN LOGON, GO TO DEVICE MANAGER AND REMOVE IDE AND RESTART, ONLY IF THIS HDD DOES NOT CONTAIN OS. YOU SHOULD BE FINE AFTER THIS, OR INSTALL YOUR OS ON THE SATA HDD.
Apr 09, 2010 | MSI K8N Neo4 Platinum nForce4 ultra K8...
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
NI8 SATA DVD Drive compatability
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Mike
Mar 22, 2008 | Abit NI8-SLI Motherboard
Seagate barracuda7200.9 80 gig.
Some of the following answer assumes a windows operating or possibly DOS based operating system. If your original OS was not Windows or DOS -- there may be different considerations.
1) Did you lose the contents of both partitions?
That depends were they soft or hard partitions.
Soft partitions are created as files inside of other partitions
If that is what you had allocated in the formatted partition
you have lost their data content.
Hard or physical partitions allocated using FDISK and some other utilities the second partition would still exist.
2) Where are/were your system files. Often but not always they appear as the first partition of the master drive on the primary IDE controller all assuming a PC (based on the master slave comments you have indicated.) (sometimes the second when diagnostics are loaded on the first partition)
a) if the partition on the drive you formated contained the system files yes they must be installed to access anything on the disk for the most part. A significant exception may be utilization of a DOS boot diskette might permit DOS access to the other partitions if they are formatted with the FAT file system.
NTFS partitions and possibly FAT32 partitions may not be accessible to all versions of DOS -- there may be some bootable CD's that would allow access to NTFS partitions without installing an operating system.
Question back from the DOS and older version of windows days and even some more modern operating systens in subsequent actions with the disk did you use FDISK or another utility to rewrite the boot blocks to point to a different partition?
Question this was not a dual boot machine was it?-- if so disregard anything that follows.
Question did the machine boot after formatting the partition and before you started moving the drives around? If so the operating system is probably on a drive you have removed from the machine. It needs to be replaced onto the same cable position it was originally located upon -- probably on the Primary IDE cable master position or jumper setting.
If not reinstallation of the operating to the formatted partition is probably the correct next step. Be careful in doing this because if you choose one of the other partitions that were not formatted it could wipe out the data in them based on the installation process chosen.
Dec 10, 2007 | Seagate 80GB Barracuda 7200.9 SATA s - 8MB...
Hard Disk and Booting issue
go into your BIOS and on the bottom of your screen there should be a (last good config) of (fail-safe config) value for one or=f the F1 to F12 buttons. also. are you running a 4gb hdd??? or is that a typo? anyhow, XP REQUIRES 2GB at all times free if your hdd is running at less that that (cause its full) your boot up could be messed around. finally make sure that the little plug on your hdd is across the Master or cable select pins not the slave as this can cause probs too. good luck.
Sep 22, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Dell PowerEdge 1800 Server Logo
268 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
