Question about Archos 604 WiFi Digital Media Player
Usb connection
Connecting to usb and it tells me buttons enabled trying to connect it to my mac computer. what the problem?
  • 456 Answers
Remove the program and then try to reinstall the software
Posted on Dec 23, 2007
How do i enable a disabled iphone 4s that shows iphone disabled connect to itunes?
Hold the power button and home button until the phone restart when it restarts hold the home button only for 10 seconds and plug in your sync cable it should connect to iTunes
Jan 08, 2016 | Apple iPhone 4S
Sync Contacts in Address Book from computer to iPHone.
On your iPhone, make sure that
  • in the Settings app
    • Mail, Contacts...-->iCloud has Contacts enabled (green button)
On your Mac, make sure that
  • System Preferences-->iCloud has Contacts checked.
If the iPhone still doesn't sync,
  • connect the USB cable from the iPhone to the Mac,
  • open iTunes,
  • make sure that "automatically sync iPhone when connected" is checked in the Summary window of your iPhone (in iTunes);
  • and click "sync" in the lower right corner of your iTunes window.
Feb 10, 2015 | Apple iPhone 5
I can't connect to WiFi. Any advice?
Is the wifi enabled, can you see any wifi networks? If not, make sure wifi is enabled, if there is button on laptop to disable/enable wifi connections, swich wifi on.
Check from control panel -> network (network and sharing center in Vista/Win7) -> change adapter settings. If wireless lan adapter disabled (grayed out).
Jun 04, 2014 | Computers & Internet
I can't get my printer to print. It seems to be stuck on Paused.
If your printer is connected via wireless network, please try the following.
1. Check if WiFi light indicator if enable and has signal strength.
2. Check if your computer is connected to your wireles router.
3. Reinstall the printer driver.
If your printer is connected via USB cable, please try the following.
1. Check if the printer and computer is properly connected.
2. (for Windows), Check Device Manager if USB Printing Support is present, (for MAC) Check Apple System Profiler if EPSON MFP 2.0 High Speed is present under USB device tree.
Nov 03, 2011 | Epson Artisan 800 All-In-One InkJet...
I find 2 strong open signals but after saving them, I cannot connect to Internet in wireless mode to those open network addresses (the TL -WA5210G is connected directly to my notebook, DHCP auto mode is...
Incase Open networks are configured for MAC authentication(MAC binding) then you might not be able to connect to those networks. Even though Network is Open (Unsecured), if ACL (Access Control List) is enabled on the network then only those computers can connect whose MAC address is configured for that Network, its another Security feature on Routers.
Try connecting to some network which your are sure are Open (Unsecured)
Jul 06, 2011 | TP-LINK TPLink TLWA5210G 24GHz High Power...
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
How do I install the D-Link X-treme N router for Mac OS X
Before you Begin
This section will walk you through the installation process. Placement of the router is very important. Do not place the router in an enclosed area such as a closet, cabinet, or in the attic or garage.
Please configure the router with the computer that was last connected directly to your modem. Also, you can only use the Ethernet port on your modem. If you were using the USB connection before using the router, then you must turn off your modem, disconnect the USB cable and connect an Ethernet cable to the Internet port on the router, and then turn the modem back on. In some cases, you may need to call your ISP to change connection types (USB to Ethernet).
If you have DSL and are connecting via PPPoE, make sure you disable or uninstall any PPPoE software such as WinPoet, Broadjump, or Enternet 300 from your computer or you will not be able to connect to the Internet.
You should not need to install anything. just reset your router with the little button right next to where you plug the power adapter. This should reset the device to simple manufacture default setup with no WEB security then go to your mac and turn your mac plug it in to your router with ethernet wire and enable local Area network and disable wireless internet connection. When you are connected with wire, To secure your network first you need to find your ip address it is usually but sometimes it might be differant Open your system preference, and then click on network.This will take you to your active connection.From here you want to Lookunder the word status. Here you will find your IP Address.
Depending on your router settings yo may get a different IP address each time you connect. So check this before relying on it to stay the same
Type in that ip address on your internet browser and enter it should go to a log in screen to your router's hosting To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (
You may also connect using the NetBIOS name in the address bar (http://dlinkrouter).
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default. once you connected enable wireless access and configure a web or Wpa secured connection and generate the web key aftre the web key generated look at the one is checked on the right side which is usually the first one wire that key down and do not loose it change your connection name change the log in name and password if you want save these settings and log off. go back to your mac and disable local area connection and re enable wireless internet connection unplug the ethernet cable and search for your connection you just named. type the web key when it is asked and save the connection after connection astablished. And you are done.
Feb 24, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Hp 2015d will not print. Everything is on and the driver is installed. We have also tried to reset printer. Powered it down.
Hi Tmthymngn,
When printer is ready. Press the Green button. A Demo page will be printed. If this works, try to connect printer to a different USB port on the computer. Computer should detect that you have a usb connected. Or connect a USB drive to the port instead. If the drive is not detected, the USB port might not have been activated. On your computer, click Start|Settings and select Control Panel. In control panel, double click on System, then select Hardware tab. Click on Device Manager button. In Device Manager window, look for Universal Serial Bus Controllers. Click on the + sign. Right Click on each host controller tand select properties to see if each is enabled and working properly. If it is disabled, enable it.
Dec 18, 2008 | Office Equipment & Supplies
Problem involving Nintendo Wii and MAC address
Try restoring the router to factory defaults. With the router plugged in, insert a pin to press the reset button. Hold it for 10 seconds then release. Your router should be restored to factory defaults then you can set it up again.
Apr 10, 2008 | Belkin (F5D8231-4) Wireless Router...
Usb connection
hub is not strong enough connect to computer usbs then rebot
Dec 23, 2007 | Archos 604 WiFi Digital Media Player
Archos 604 WiFi Digital Media Player Logo
37 people viewed this question
Top Archos Audio Players & Recorders Experts
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
