Question about Car Audio & Video
Can't save radio stations. I can find them OK but when I switch engine off in car I loose them again. wharfedale WCA7332 car radio
    Top Expert:
  • Car Audio & ... Master
  • 75,222 Answers
U have no keep alive memory power, check the radio fuses.
Posted on Oct 05, 2009
Radio frequently just stops broadcasting and eventually comes back on
Peggy, Is the radio actually switching off or do you just loose the radio station. If radio is shutting off, there must be a bad wire/ plug connection, loose plug, or maybe bad ground.
If loosing station, have Arial/antenna connections checked, maybe upgrade to better antenna. Some stations just do not send out a strong signal which can also cause loss of station.
Mar 29, 2016 | 2009 Toyota Highlander
Don't know how to save and assign radio channels
ok change the channel to what u want to listen to then hold the number 1 button for like 3 sec or 5 secs then that channel is programed to channel 1 repeat steps for button 2 3 4 5 ect... with ur other fav stations u like to listen to.. then u can press the fm button to go to fm 2 which again u can program 1 through how ever many channel numbers ur radio shows now program different stations other then the ones u just programed on fm 1 choose 5 or 6 other station the fm2 just offers u more stations to program other wise just program the normal 5 or 6 stations to ur radio
May 16, 2011 | Car Audio & Video
3 problems with my wharfedale ics182. 1. The stations are not stored when turning off the radio and then switching back on. 2. When turning the ignition. the radio does not turn on. my other radio does...
Swap the battery and accessory lead positions in the ISO header plug. This is easily done by pressing the pins out from the plug side using a fine bladed screwdriver.
_MANY_ cars have these 2 wired the "wrong" way in their radio socket. It's far easier to move the radio's wires than the cars.
Once you've done this your bluetooth will probably sort itself out too.
Dec 29, 2010 | Car Audio & Video
Wharfedale wca7332 wont turn on after disconnecting the battery
Has anyone answered this problem yet? I have the same problem...
Aug 21, 2010 | Wharfedale DVD-M3 DVD Player
Trouble storing radio stations
IF this aftermarket fitted then the ignition live and permanent live feed to the stereo are configured round the the other way on the head unit.i think it may be the red wire and yellow wire need swapping.
Dec 30, 2009 | Radio Communications
I have a 2001 VW Polo with a factory fitted radio, cassette cd player. It's started to switch to the cassette player (which I've never used) and when I switch it back to the radio there's no sound. I...
Hey there! I had the same problem just the other day and removed the radio from the car over night.
Turns out the radio may have got too cold or a little damp! Whereabouts is your car stored overnight? Could be the reason why!
Either that or one of the buttons could be stuck. Hope this helps
Dec 06, 2009 | Car Audio & Video
Loosing all ive saved when i turn the engine off
Easy fix, There are two 12+ volt feeds that should be connected to your unit.
1. Constant feed = 12+ volts that supplies power to the units memory all the time.This wire can be connected from the original radio connector wiring so long as it supplies constant 12+ volts, or be pulled from the battery, with an in-line fuse.
2. Switched feed = 12+ volts that only supplies power when the ignition switch is turned on,This wire can also be connected from the original radio connector wiring so long as it is a switched feed, also with an in-line fuse.
During installation ether these wires were swapped or the constant feed (memory wire) was not connected.
Good luck...
Feb 24, 2009 | JVC KDAVX44 Car DVD Player
KENWOOD KDC - W312SAY BUTTON MEMORY 1 - 6 NOT WORKING
what is the problem but if you want to memoris your station you just search for the station and press and hold the burton number #you wish to program it on
Dec 10, 2008 | Car Audio & Video
Pioneer DEH-1700R - Storing Radio Stations permanently
your constant power wire is not hooked up or it has come loose that is why nothing will stay saved on the unit have it looked at and see if they wont fix your problem cheap...... its a easy fix
Sep 16, 2008 | Pioneer DEH-1700 CD Player
Car Audio & Video Logo
169 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
