Question about Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Convert from natural gas to propane
We have the conversion kit for our Duet Sport 6.7 cu. ft. dryer and we know we need to change the orfice, how do we do this? Do you know if there are any do it yourself instruction manuals or guides available? Or can someone tell me the process?
Do you have to change the orifice?
Posted on Apr 04, 2010
    President:
  • 1,304 Answers
It is very simple
pull of the botom toe kick
3 t-20 screws
once the toe kick is off
you will see the gas valve
disconnect the ignitor
remove one 5/16 screw
the whole assembly will slide out
if you look at the top of the tube
you will see the brass orifice
this needs to be replaced
Posted on Oct 06, 2009
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 | Dryers
Wanting to change propane stove to natural gas,need parts to do that
Most ranges can be converted with the orfices being changed.Newer ranges have the orfices under the top.Older ranges can be convetrted by drilling the orfices larger.(propane orfices are smaller than natural gas.Sears can sell you a conversion kit if you know the model and serial #.Most Gas companies will convert it for a fee.
Mar 05, 2014 | Kitchen Ranges
Need to change from LP to propane. How do I get access
Gas to Propane requires a Propane Certified technician. These technicians are provided by the company that provides Propane that they will be using.
You may need to get a Propane conversion kit, for technician from the Propane company to install.
You can certainly double check on this...Hope this helps.
May 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet gas to propane conversion
no you definately need to change orfices from gas(line) to propane, call your gas supplier for a conversion kit or go to an appliance parts store and they will help you on this on this matter,don't try to start this unit after change-over if the orfice isn't right, i tried it and found out tooooooooo late
Apr 04, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
I just converted my DUET "sport" dryer from propane to natural gas,orfice and regulator cap, and now the burner does not come on.
Hi, I'm going to start with asking the most obvious thing, no offense. Is the gas turned "on"? Does the hot surface ignitor "glow" ? The valve should be open at the burner supply tube as well as the dryer supply line. I've seen it happen often where the burner valve was shut "off" and forgotten when the repairs/conversions are complete. You could loosen the fitting at the burner to insure you're getting gas flow to that point. That way you know for sure it's likely a bad ignitor or coil etc. The ignitors are quite sensitive, and if disturbed or knocked around can crack, then it's toast. Hope that helps, good luck
Oct 19, 2009 | Whirlpool GGQ8831L Gas Dryer
Converting a Propane Thermador 36" range to Natural Gas
I have the same range but need to convert it from natural gas to propane....we should trade...9j antiques
Aug 31, 2009 | Thermador PGR366 Gas Kitchen Range
Converting from natural gas to propane
you need to change your orfice or you will have a big problem with flame
Jun 01, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
Changing a gas ge dryer to a propane----convertion package we25x10014 directions show a picture of the control panel with 4 plug ins at the bottom and changing out the last one on the right for the new...
Converting your Natural Gas Dryer to Lp is taking it from a lower BTU gas "Natural" to a higher BTU "LP" value. The orfice on a LP gas valve is smaller because you dont need as much gas to make the same amount of heat. make sure you change the orifice. The little plug goes in the regulator of the gas valve, changing the valve from a low gas pressure Natural to a Higher Pressure LP.
If the kit doesnt look right, did you get the correct one?
Maybe you should call you LP provider they can do the conversion for you.
Jul 10, 2008 | Dryers
Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer Logo
182 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
