Question about Ricoh Aficio GX3000 InkJet Printer
I replaced the ink waste tank on my Ricoh GX3000 - then it asked for new yellow ink cartridge and I replaced that. Now I have an error code 990 and I can't get rid of it.
Bonjour,
allume ton imprimante,puis retire toutes tes cartouches.
eteint l'imprimante.
rallume l'imprimante et remet les cartouches.
le code d'erreur 990 indique de l'air dans les tuyaux.
ça devrait marcher!
Posted on Apr 24, 2010
After replacing the ink waste tank, I am still getting an error stating replace waste ink tank full on an Ricoh GX3000 all in one.
This may have to do with the method of replacement. Leave the printer on, remove the waste tank, clean the area (sensors may detect residual ink) replace the empty waste tank. If this doesn't work, there may be a chipset on the waste tank to indicate end of life. This is a way for the manufacturer to continue making a truckload of money from the end user. Generally the only way around this is to modify your printer to by-pass this part of the circuit (an electronic solution to replace the chipset). This method will most likely void your warrantee.
Aug 25, 2010 | Ricoh Aficio GX3000S multifunction Ink...
Error code 990 still after reset. what to do
Error 990 is an error message that has to do with the ink drying out on the maintenance unit. Unfortunately this is a fatal error and the printer will need to be replaced as the maintenance unit can only be fixed by a technician. You will have contact Ricoh for further information on possible replacement.
Apr 09, 2010 | Ricoh Aficio GX3000 InkJet Printer
INK DEPLETED BLOCKING ALL FUNCTION
Both of the cartridges did need replacing; the black is OK now so just pop in a cyan and you should be fine.
May 27, 2009 | Ricoh Aficio GX3000 All-In-One Printer
Have error code 990 on ricoh gx 3000 printer how do i clear this?
you can try pulling out and reseating the Waste Ink tank which is located behind the machine behind a plastic door cover (left side of machine as you are looking at it from behind). Turn the machine off and on using the main power switch. If the code comes back then you will more than likely need a new Waste Ink Tank.
Mar 23, 2009 | Office Equipment & Supplies
I have a Ricoh G7500 printer that is giving me an ERR-990 when I turn it on. I don't see any documentation on Ricoh error codes.
990 A Waste Tank Full Sensor Defective
The waste ink tank full sensor (a
photosensor) on the corner of
the waste tank is not operating.
• Waste ink tank sensor on the corner of
the ink waste tank is defective.
• Replace the waste ink tank.
Aug 23, 2008 | Ricoh Office Equipment & Supplies
Hello, we're getting an error code of 990 on a GX5050n inkjet printer. The printer is fairly new with only a dozen or so printouts. Thanks.
make sure printer is off. Then old down escape and online button at the same time. Continue to hold these two buttons down then turn on printer. Continue to hold those two buttons down (will take about 2 - 3 minutes). This should clear that message - worked for me!!!
Aug 07, 2008 | Ricoh Aficio GX3050N Printer
Ricoh GX3000
ERR (990) or ERR (999) are both error messages which are displayed when a sensor does not work normally due to dirtiness. For example, either may be caused by a dirty maintenance unit or clogged ink nozzles. It may be possible to resolve the issue by cleaning the device
look here for instructions:
http://www.ricoh-usa.com/support/knowledgebase.asp?tsn=Ricoh-USA
Jan 25, 2008 | Ricoh Aficio GX3000 All-In-One Printer
Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Aug 19, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
Ricoh Aficio  GX3000 InkJet Printer Logo
635 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
