Question about HP Compaq nx9020 Notebook
Need drivers error 39 - HP Compaq nx9020 Notebook
  • Jacqueline May 11, 2010
    what driver are you looking for?
    Guru:
  • 441 Answers
You can download all your drivers here:
Just select your operating system (Windows XP) and all the available drivers will show.
Hope this helps!!!
Posted on Jan 04, 2010
FaultCode:0 faultString:'Error' faultDetail:'ioError: ioError'
Two of the most common causes of I/O (Input/Output) device errors are driver based. Typically, either the device's driver is not enabled or it is out of date. The driver component has an important function, as it acts as a motor like force that propels USB/plug-and-play hardware into a driving action within the computer. It is the connecting communicating link signaling the CPU to a desired movement. And while not all I/O device error solutions are simplistic, as a good starting point, you can try troubleshooting using a few basic steps, and you might not need to attempt anything else.
Access "Control Panel" from the Start menu and then choose "Performance and Maintenance." Click "System" and then go to the Hardware tab and click on "Device Manager." Find the device that is registering an error by expanding the nodes of the appropriate category. If the device has a red "X" on the icon next to its description, the hardware is disabled; Otherwise, Go to the General tab and click "Enable Device" found under the Device Status section; then press "OK." (Note: You may have to follow prompts, as indicated through an enabling device wizard. If you do, continue to click "Next" and follow the prompts until the process has completed.) Test the hardware. If an error is shown. Go to the General tab and click "Troubleshoot" found under the Device Status section then press "OK." Follow the prompts to solve the issue. If an error is still shown Go to the Driver tab and click "Update Driver." Follow the prompts until the process has completed and then test the hardware. Hope this helps.
Dec 09, 2012 | Microsoft Internet Explorer 9
No sound when playing cd on 3150 averatec laptop
Check Device Manager. Right click on My Computer > Manage > Device Manager > Sound, video... Make sure there are no errors. Error will indicate drivers required.
Aug 27, 2012 | Averatec 3150 Laptop/notebook
Overflow error
That's a software error for which the developer should be informed and they'd usually issue a patch that takes care of it.
Sometimes it may not be the game developer that's the source of the problem, but since it's their game you'd usually call them, describe your hardware setup and help them reproduce the problem so they can find its source.
Basically it'll be either their game or (usually) a video driver , usually a DirectX driver.
Check for the latest DirectX update but above anything go to EA's website and ask the question there.
Aug 25, 2012 | EA - Electronic Arts Need For Speed: Hot...
Cd drive code 39
What the Code 39 Error Is
CD-ROM/DVD Drive Cannot Start. (Code 39)
Code 39 is an error specific to the device manager. It is directly associated to drivers and errors that have occurred within them. Drivers are the small pieces of software that your hardware devices use to function. Each hardware device has it's own unique driver, developed by the hardware manufacturer, that contains the instructions allowing the hardware device to cooperate with other hardware devices and communicate with the operating system. Drivers are essential to the normal operation of any computer as they bridge the gap between hardware software.
Code 39 errors are amongst a wide array of device manager errors that all point to the same problem: the driver. It is not uncommon for drivers to become corrupted and produce errors during normal operation. Drivers are accessed constantly for every operation that a hardware device performs. Because of this, there are thousands of opportunities for errors during a single session of Windows. Because of this high rate of failure opportunity, many users have experienced Code 39 errors as well as many other device manager errors.
manually fixing Code 39 errors. Updating to the most current driver will replace the corrupted file with a new, better driver. Updating the driver will not only correct Code 39 errors but it will also introduce greater speed, performance, stability and compatibility. Driver updates are changes that the developer made to the original driver in the interest of all-round improvement. Driver updates often correct many other errors that are related to device incompatibitlity.To learn how to fix Code 39 errors manually, read this guide. The guide will provide steps for manually finding, downloading and installing the most current driver avaiable for your hardware devices. However, it is generally MUCH easier, safer and more reliable to use an automated tool. We've discussed using an automated tool to fix Code 39 errors below.
DriverUpdate.DriverUpdate is an easy-to-use tool that scans your unique hardware configuration for any device driver problems. Drivers that are out of date, missing, misconfigured or corrupt can easily be re-installed automatically by the program. The benefits of this program are endless. Most users not only have error messages fixed, but also will see a performance improvement since all of their system drivers can be updated! ( click here to download DriverUpdate ) RECOMMENDED
Feb 23, 2012 | Dell Dimension E310 PC Desktop
Driver for iphone4 code 28
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 28 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue. Cause of the Code 28 Error A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Error Code 28 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
  2. Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
    Undo the change, restart your PC, and then check again for the Code 28 error.
    Depending on the changes you made, some solutions might include:
  3. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
    Important: Make sure you install the drivers for the correct operating system. For example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Many Code 28 errors are caused by attempting to install the wrong drivers for a device.
  4. Install the latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
    Note: I do know that certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
  5. Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Please let me know if you've fixed a Code 28 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Jan 08, 2012 | Microsoft XP Computers & Internet
Error code 39
error code 39 causes due to missing driver, hardware problem or wundows registry. It mostly appears in DeviceManager. Just rerstart you PC it will be fixed if not then reinstall the driver of particular hardware which you have added or installed from device manager.
You need to have a systenm utility software like RegInOut to fix windows registry files and different drvers and operating systems errors.
Dec 24, 2011 | Gateway Computers & Internet
The drivers for this device are not installed. (Code 28) There is no driver selected for the device information set or element.
Resolution
    • Remove or reconfigure the newly installed device.
    • Roll back the driver to the version prior to your update.
    • Use System Restore to undo recent Device Manager changes.
Applies To The Code 28 error could apply to any hardware device in Device Manager but most Code 28 errors seem to affect USB devices and sound cards.
Any of Microsoft's operating systems could experience a Code 28 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 28 Issues in Device Manager? Let a community of computer support enthusiasts help out! Post the details of your problem in the PC Support Forum. Be sure to let us know that the exact error you're receiving is the Code 28 error in Device Manager. Also, please let us know what steps, if any, you've already taken to try to fix the problem.
----------------------------------------------let me know if this helps--------------------------------------------
Jun 20, 2011 | Computers & Internet
When i install audio driver of lenovo g450 then it shows a error
Hi kumar,
I see that you are having an Error when installing your Audio driver, what sepcific Error would be having?
If the Error is saying that the deivce audio is not detected then there is something wrong with your Audio card on the machine and may need replacing.
Also installing the correct drivers for the Audio card will avoid getting any errors on the issue, try going to consumersupport.lenovo.com for the drivers that will be specific for your lenovo. Your drivers will depend on what Operating fsystem you will hve on the Laptop make sure that you selct the driver that for the Oprating system that you have to avoid getting Error's.
NOTE: if ever you still get Error's from any Audio driver that youv'e tried most probably you will need to try and restore your Lenovo back to factory Defaults by using the One Key Recovery Button to set everything to factory defaults and see if the Audio card will work properly.
Also make sur that you back up any personal data before doing the One Key Recovery option.
I hope that this will help you regarding your query.
Have a nice day,
mvincentc
Apr 19, 2011 | Lenovo G450 Notebook
Error 39 no driver found
I suspect you need to perform a little Registry surgery. Sounds suspiciously like an upper and lower filter and /or driver problem. See link below for instructions
http://support.microsoft.com/kb/314060
Although other things may cause your problem, it definitely will not hurt to install a clean driver.
Note: Registry edit is needed to properly re-install driver
Jun 17, 2008 | Computers & Internet
HP Compaq nx9020 Notebook Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
